Aftermarket Injectors program
Old Oct 13, 2007 | 07:53 PM
2007 5.9's Avatar
With the Aftermarket Injectors program from SAMRTY, does it remove all timing and just run stock timing? I was wondering this cause with stock injector program on level 2, it feels the same as running aftermarket injector program and on level 3. Just curious.....
Old Oct 14, 2007 | 02:44 AM
LVTony's Avatar
The odd levels on aftermarket have more timing than stock, but less than the other Smarty softwares on odd. Even levels have no timing added so you can stack (as you have).
Do your injectors sound the same between stock (mild?) #2 and aftermarket #3? That's the main reason to run aftermarket injectors software.
Old Oct 14, 2007 | 10:09 AM
2007 5.9's Avatar
Yes, they do sound the same running even SW# with stock SW, and running aftermarket odd#'s. I went to running aftermarket software due to the rattle that I got from running stock sw on odd #'s.
Old Oct 14, 2007 | 10:57 AM
Special Blend's Avatar
I did the same thing with my truck. I was running SW#3 and had a lot of timing rattle. I downloaded the aftermarket injector program but it felt weaker then the normal program did. Main way I could tell was passing on the highway. Truck would downshift most of the time. I loaded up SW#5 and it feels pretty much the same as SW#3 for the normal program.
Old Oct 14, 2007 | 12:11 PM
2007 5.9's Avatar
So you're saying that running SW#5 Aftermarket injectors, feels like running SW#3 with stock injector programming? If so then I will load up sw#5 ASAP.....
Old Oct 14, 2007 | 01:49 PM
Big Horn 06's Avatar
On mine, I got a Roktec sensor, so when I'm running the aftermarket inj program, I still got a bit more timing (or so I hope anyways) than just the program. She's still pretty quiet.
Old Oct 15, 2007 | 03:16 AM
LVTony's Avatar
Yeah, aftermarket mild #3 does seem to not make as much power. I was weird, though. When I ran stock mild (before the tranny), I preferred #1 to #3. #3 had better passing power on the highway, but #1 seemed to work better in the city stop and go. I never ran higher than #3 before I got my tranny.
Old Oct 15, 2007 | 05:39 PM
DaveB.inVa's Avatar
Doesn't #1 have more timing than the rest of the odd numbers anyway?
Old Oct 16, 2007 | 03:22 AM
LVTony's Avatar
That would explain it, but I have no idea, or way to measure, if that was the case...
TexSoftail
Feb 5, 2008 08:09 PM
Ghost Ram
Jan 7, 2008 08:09 PM
2007 5.9
Sep 6, 2007 07:47 PM
Shank
Aug 27, 2007 10:58 PM
bluebull
Aug 16, 2007 04:51 PM
