Aftermarket Gauge Questions
Installed my new Edge Insight over the weekend. Had a chance to put a few miles on it today. At 65 mph sustained, with an outside temp of 60, my EGT's were in the 700 degree range, my rail pressure was in the 17,000 psi range, my tranny temp was 165, and my boost, when on level ground was between the 7 and 8 mark.
Are these numbers about right with what you're experiencing?
What are the upper safe limits, so I know what to look for?
I sure hope you mean rail pressure. From what I have read your numbers are about the norm. fuel pressure depending on what FP you got can be from 10 to 20psi or higher. WOT can bring the oem pump down to 0psi depending on mods
kawi600
16
Aug 27, 2009 10:23 PM
I PASS GAS
Mar 16, 2006 07:59 AM
mtl0727
Oct 12, 2005 01:02 PM
Greeds22
25
Sep 11, 2005 03:13 PM
engcogod
17
Feb 3, 2005 08:49 PM
