Aftermarket Brakes anyone??? need advice, first brake job comming up
Old Feb 2, 2006 | 05:13 PM
Igor's Avatar
Originally Posted by vernl
i found out the hard way that our rear discs are vulnerable to having the caliper pins beat up and pitted from debris thrown form the front wheels so that they dont ''float'' when the brakes are released...I replaced a rear set of pads and put new caliper pins in my last truck after messing around in the mud all last summer...have a peek at the back calipers and see if the little rubber boot is trashed..if so..you are in the same boat as i was...anyway..there is a $100 fix..they make caliper guards that bolt on quick and easy and when i bought my new truck i had them put on from day one .. if you spend any time off the pavement they will pay for themselves after the first brake job
Yes, my boots were done, and i replaced the caliper boots and put the guard shield on. And I do take a LOT of gravel/mud roads, that's what the environment the truck works in.
I'm gonna have to check them myself, and decide from there.
Thanks guys.
Old Feb 3, 2006 | 04:18 PM
6 2 Carl's Avatar
I found the hard way as well that apparently our trucks are not designed to travel on gravel roads??!? At 36,000km my rear caliper pin boots were torn up. This is completely unaceptable, the caliper guards should be installed at the factory.
Carl
Old Feb 4, 2006 | 04:53 PM
tristan21's Avatar
I have a house on a gravel road also (cant talk the guys at the end of the street to pay their half of the asphalt) where can I get these guards from and are they nothing more than a little bracket with a metal cover to keep tha stones out? If so I guess I could make a set I've got some thin stainless lying around and a brake. Maybe I'll go look at it.
Old Feb 4, 2006 | 05:29 PM
vernl's Avatar
i have always bought mine at the dealership but dont think they are a dodge part..they just bring them in, they look like a c- shape with perhaps an 1 1/2 inch lip protruding to protect the caliper they mount in front of the caliper using the caliper bolts and existing holes and are made from quite heavy steel but anyone who has access to a bit of fabricating equipment would only have to look at a set and be able to make them up in an hour or so ..i think the reason they are built as heavy as they are is that if you got into some heavy clay mud anything lighter would likley crumple..but they really do the job
Old Feb 4, 2006 | 06:31 PM
Scotty's Avatar
Top's Younger Twin
Just reading the name Eastside made me cringe and I had a flash back.
thanks. LOL
Does Varsity own Crowfoot still?
I have over 80K on my brakes, I will get them checked this week...at a brake shop I trust here. I was also told the MOPAR pads are a good bang for the buck.
A Canuck buck. eh
Scotty
gofastman
13
Feb 4, 2013 01:00 AM
Red Ram
Aug 14, 2012 11:42 AM
wildcargo
Nov 29, 2005 04:20 AM
Ram44maR
30
Aug 25, 2005 02:45 PM
J BODY
Apr 17, 2004 07:51 AM
