AFE Stage 2 versions
I have a question since I am planning to get an AFE Stage 2 Intake, since its seems its the most popular here. The question is, which one to get, since I see there are two versions:
1) AFE Cold Air Intake
Cold Air Intake System, Stage 2 System, Includes Air Box, Filter, Intake Tube, Instructions And Hardware, Adds 50 Horsepower And 100 Lb Ft Of Torque.
Cost: $450
2) AFE Cold Air Intake
MAGNUM FORCE STAGE 2 COLD AIR INTAKE WITH PRO GUARD 7 FILTER AND TUBE, Adds 50 Horsepower and 100 Ft Lbs Of Torque, Increased Fuel Economy, Heat Shield Replaces Factory Air Box And Intake Tube, Includes Pro Guard 7 Lifetime Reusable Filter, Instructions And Hardware
Cost: $493
I saw those 2 at: http://www.autopartswarehouse.com/ , and both are advertised for the 5.9 diesel. Mine is a 2007.
What is the difference between them, which one is better or are they just the same and wouldn't notice the difference.
Also, where I can find the best price for these, excluding ebay?
Thanks.
Cost: $450
Cost: $493
Thanks.
Cost: $450
Cost: $493
Thanks.
Cost: $450
Cost: $493
Thanks.
I would keep looking if I were you. Those prices are a little high. The Stage II will cost a little more because of having the tube.
IMO, I'd go Stage II. That or at least gut to OEM tube.
there's no difference in those two. They do make a Stage I and Stage II. The Stage I just doesn't come with the torque tube is the only difference.
Me too. I think it adds like 4 hp and 11 ft/lb to the Cummins engine....
what he posted though are the same thing only listed different.
there's no difference in filter size and they both come with a Pro Guard 7. They didn't used to but, go look at AFE's site. the only differene is the filter housing and torque tube. Yes, the Stage I has a smaller inlet but, that's beause you didn't go as far as to buy the Stage II that replaces the tube.
I agree, the two above intakes are the same system, one with the standard filter and one with the PG7.
I just wanted to make sure people reading this didnt think they could mix and match parts and filters from a stage 1 to a stage 2, or vise versa.
And, those prices are more than a little high, keep lookin you can do better than that.
afe stg II prodry
they also have another version in the stage II. Its a dry filter instead of the one you oil. it flows a little better sounds alot meaner and its alot easier to clean. the part # is pn 51-10932. call larry here at the dtr store for a price. he's the cheapest and friendliest i found.
JMO, and food for thought....
As and addition to my last, the PG7 is recommended for applications where you may encounter higher than normal dirt ingestion (IE desert, jobsite, oil rigs, offroading).
I contacted Michael Cain at AFE a while back and this was what he mentioned.
I have both the PG7 and Standard, I also use the prefilter.
