Afe Stage 2 Intake
Afe Stage 2 Intake
Please tell me once and for all, is the AFE stage 2 intake worth getting? I am not about to throw down 420.00 for an intake if I will see little or no difference in sound and performance. Is it worth the money?
my opinion says keep your torque tube and toss in a BHAF, I get looks all the time, people wondering what turbine I have running in my truck, I tell em one off an a10 thunderbolt..... & some actually believe me!
Edit : with the money you save you can just about pay for one of these and really wake that truck up
http://store.dieseltruckresource.com/doxzstadjmo3.html
Originally Posted by Big P
I just bought an AFE stage 2 and I'm not too happy with it. If you do your own oil changes you will know why I don't like it. It is a PITA to get that thing re installed.
LCH
AFE Air Intake Systems
Graphite 600,
In no way do I wish to harm AFE's reputation but, since it's your hard earned money & YOU ASKED, I will tell you my recent experience, backed up with not-so scientific numbers.
Last week, I installed a Van Aaken C-3.2 duration box on my '03, HO, 6-sp., 3500, 4X4. I did some pre-install, stock testing, added the box then did the Tone ring Mod & finally an AFE ProGuard-7 Air Intake System w/ the metal Torque Tube. I did 40-65 mph, full acceleration runs in fifth gear & used a stop watch for the timing. Admittedly, this is not as accurate as dyno runs but, I would have gone broke paying for someone elses dyno, with all the runs that I did. And, I was just interested in the approximate differences each of these mods made.
I did three runs with the VA/3.2, Tone Ring Mod & the stock air box & "clean" filter.
I, then did three more runs with the VA/3.2, Tone Ring Mod & a "clean" AFE PG-7 with the metal Torque Tube. Two of the runs were identical to the "stock air box" runs & the third run showed an improvement of 1/10 of one second. Not a very cost effective increase, to me. In fact, I'm VERY disappointed!!!
If I had to do it over, again, I would either "swiss-cheese" the bottom of the airbox or go with Performance Systems Mfg's. fresh air intake (psmbuick.com).
If you build or buy a metal torque tube, which I believe you have already done, & remove the silencer ring, you should get pretty good turbo sound even without the aftermarket air intake systems available.
With the money left over, you can invest in a box, which, should really enhance your trucks performance.
Previous to my recent fueling & timing mods, I had the AFE PG-7/TT system installed & removed it to reinstall the stock airbox, for trips to the dealership. I noticed NO power loss from going back to the stock airbox. In fact, to my surprise, I BELIEVE, I noticed an, ever so slight, increase in performance from the stock airbox. I, certainly, did not expect that!!! In fact, I was happy with the sound & looks of the AFE product. Just surprised at it's lack of increased performance.
Again, in no way do I wish to be disrespectful to AFE & their products. I think they build a quality, well built product that seems to filter as well as advertised (according to my used oil analysis test). However, in my experience, I did not realize the performance increase that I was expecting.
Joe F.(Buffalo)
Joe F.(Buffalo)
I have the Stage 2, I like it. It seems to EGT's I did the exhaust @ the same time, but I the the combo has worked well. The most cutback I see on the juice is 2% I account that to getting more in and out over the stock air box and exhaust. The thing is way loud with the ring out and the top cover off, I but them both back in.
Buffalo has good info but keep in mind its a torque tube system, the stage 2 is diffrent for the 600's its all one piece, and the 6" on the filter and the tube is diffrent than the torque tube set up.
I am no expert or claim to be one. Just giving my $.02
I have the stage 2 kit with proguard 7. The stage 2 kit is different. It has a metal box to help keep engine heated air from going in the intake. When I watch the intake air temp at highway speeds it is always 8 to 10 degrees higher than the ambient temps. (as long as the sensors are accurate) The factory box pulls outside air which may be better than lots of aftermarket stuff. I`m just trying to be helpful. I get to the oil filter from the bottom and its easy for me, than again I thought it was easier from the bottom when I had the stock box.
I too am tryin to decide on witch filter to get but with my stock air box I just pull out my inner fender well to change my oil. Its just 7 little 8mm bolts and the fenderwell just drops down on my tire out of the way.
3500eh
Jul 29, 2008 04:53 PM
TORQUE BEAST
Jun 8, 2008 07:53 PM
goodeyesniper75
Aug 29, 2007 11:54 AM
052500#1
13
Jan 6, 2006 03:27 PM
but we'll see! oil changes are easy if you go from the bottom.
