Afe
Old Feb 18, 2008 | 05:42 PM
chamisi's Avatar
Afe
has anyone ever heard not to run a oiled filter on a turbo? engine.
Old Feb 18, 2008 | 06:24 PM
chipmonk's Avatar
has been talked about a lot. i have heard from a diesel tech/friend, that there is the possibility of sucking oil into the intake, and in turn into the turbo. have heard of some dealerships that will not honor warranty work on a turbo, if you're running an oiled filter.
Old Feb 18, 2008 | 07:02 PM
05CTDN8's Avatar
Been running mine for 42,000 and every time I clean the filter I swab the tube.....NO OIL in there. Be smart about it and dont use 2 cans of oil for 1 filter cleaning....
Old Feb 18, 2008 | 07:38 PM
RamWheelsBy4's Avatar
I ran AFE Stage I and then Stage II oiled filters for nearly 60,000 miles. I had both ProGuard 7 and Standard AFE filters(used standard on track for more air flow). I have since switched to the AFE ProDry S filter simply because it is easier to clean. I still swap one of my ProGuard 7 filters when I clean the Pro Dry S for a few days. As long as it is cleaned and re-oiled properly it should not be a problems.
sinawalli
Mar 5, 2011 08:43 PM
surfram
Jul 17, 2006 02:06 PM
diesel_work
Oct 8, 2005 12:25 PM
sawboywv1
Jul 15, 2004 10:31 AM
thecatsfan
15
Mar 14, 2003 10:21 AM
