AD100 or AD150???
Old Nov 6, 2008 | 10:04 PM
glocklove's Avatar
AD100 or AD150???
Okay some one please shoot me!!! I have been huntin off and on all day about weather I can use a AD150 or do I have to use a AD100. Searched, went back loooong ways in the threads and could not find the answer.
So with what I have can I run the 150 or will I hurt somethin? I would perfer to do this mod once not twice and put another 500 bucks out.
Old Nov 6, 2008 | 10:08 PM
madhat's Avatar
Administrator/Jarhead
Go with the 150. I have it, and maintain about 20 lbs of pressure at the CP3.
What are you worried about hurting? I think that the only thing different on the instal is that you have to drill the tank to insert the draw straw.... note on that... drill it right infront of the FSU... not behind, or you'll suck air when you hit the brakes...
Old Nov 6, 2008 | 10:36 PM
Power Ram 4X4's Avatar
I put the airdog 100 30psi pump on mine. Really like it and no drawstraw to worry about runs aboud 28-29psi all the time even at wot.
Trent
Old Nov 6, 2008 | 10:42 PM
rip 112's Avatar
If you're staying below 600hp AD100, over 600 Ad150. JMO
Old Nov 6, 2008 | 10:54 PM
98whitelightnin's Avatar
We put a raptor 150 on my grandpas truck and all he has is a edge ez and it works great. The 100 will have more pressure but the 150 will flow more fuel per minute. We went with the biggest one the first time with no regrets.
Old Nov 7, 2008 | 06:37 AM
Bad-Duvall's Avatar
150 if you like to do things once!
Old Nov 7, 2008 | 06:39 AM
megacabdad's Avatar
Like the quote on here, "the only time you have too much fuel is when you are on fire."
Bigger is better in this circumstance, IMO.
Old Nov 7, 2008 | 03:06 PM
Fisherguy's Avatar
What he said, the 100 is all most of us need.
It also depends how handy you are, my AD100 and modified Liberty canister works well but it takes a little fiddlin with the return line to get around the low fuel issues.
If you go with the 150 you'll end up doing 2 draw straws if you use your stock canister or the Liberty.
nasty01cummims
Aug 6, 2010 02:55 PM
nasty01cummims
Apr 10, 2009 08:11 PM
stealman1
26
Jan 23, 2009 03:28 PM
kdbvulcan
Dec 13, 2008 11:17 PM
ClayBob
13
Dec 4, 2008 11:16 PM
