7in Stacks Anyone??
Old Oct 1, 2006 | 08:33 PM
  #61
D.Wiggs's Avatar
Originally Posted by J Double
Moderators---can we change the title to this thread to...
" 7" Stacks & 22.5" wheels "
You mean they aren't the same thing!
Old Oct 1, 2006 | 11:02 PM
  #62
Cajon's Avatar
Question
Originally Posted by JD Dearden
Hey Cajon you don't want to run all aluminum on the back!
Why not? Checked depth,ok, what will be my concern? I know that they are 1in wider than the steel/aluminum setup. The 22.5x 8.5 are 1/2 in thick at base mount and the 22.5 7.5 are 1in thick at base mount.The steel base mount are 3/8.My concern are tying to locate 22.5x7.5 in steel.Came across plenty of aluminums.also I was told they are 30# lighter.Have not check for myself just what I was told.But I am here for info, before I take the next step.Thanks again.
Old Oct 2, 2006 | 04:08 AM
  #63
XLR8R's Avatar
DWiggs - what is the inflated outside diameter of your tires?
Old Oct 2, 2006 | 05:29 AM
  #64
1st gen Hobie's Avatar
30 lbs a tire? or all around.
Old Oct 2, 2006 | 10:22 AM
  #65
JD Dearden's Avatar
Well as far as running 2 aluminums I was told that in the winter you will get some type of reaction and that they will forge together and it is nearly impossible to get them off, so maybe I was told wrong but that is what I heard. And Wiggs there is no downside to a steering stabalizer if I were you I would get the hydrolic assist one from Rocklogic, It is neat because your tires will not move unless you move the wheel, even if you hit a big bump or whatever. You can also get stiffer shocks or do a dual shock setup. Any of these will also help to prevent d wobble.
Old Oct 2, 2006 | 10:24 AM
  #66
JD Dearden's Avatar
Also I can get you the norrow steel ones if you need me too. But you are correct about weight the steel rim is way heavy.
Old Oct 2, 2006 | 10:53 AM
  #67
Cajon's Avatar
Thank you for your reply. On the steel wheels where and how long, are do I get them from you.I have heard of this condition on aluminum in boats but any thing is possible.If it does have to do with cod , down here on the Gulf coast corrsion and rust is a big factor, but not the cold,Thanks again.
Old Oct 2, 2006 | 11:38 AM
  #68
D.Wiggs's Avatar
36.9" According to Sumitomo
Old Oct 2, 2006 | 11:39 AM
  #69
D.Wiggs's Avatar
Can you order from Rocklogic online? Do they have a setup for the Megacab? It does sound neat!
Old Oct 2, 2006 | 11:43 AM
  #70
JD Dearden's Avatar
Ya the guys name is Seth tell him Jared told you to call. The website is www.rocklogic4x4.com, I am going to put this on it is a little overkill but I like that ya know. Also you may want to talk to him about installation so you can have an idea. If you go to there website you can read about it on the second page.
ryanihf250
Oct 3, 2007 01:37 AM
nfsommer
21
Apr 4, 2007 03:45 PM
rockittboy
Feb 3, 2006 12:38 AM
PistolWhipt
32
Feb 19, 2003 04:40 PM
