6" lift kit problems
Old Mar 17, 2005 | 10:29 AM
  #31
jr183's Avatar
Hi Bigge,
Just checking into see how your lift vibration problem is going. Any new solutions?
Thanks,
J.R.
Denver, CO
Old Mar 17, 2005 | 04:10 PM
  #32
cquestad's Avatar
I bet his caster is too little...good luck.
Old Mar 17, 2005 | 04:39 PM
  #33
bigge's Avatar
The 1/4" longer upper control arms killed a lot of it i also put the superlift transmission drop bracket on which took away a little more. I am going to get an alingment in the next couple of days and we'll see where we are at from there. I will let you know ASAP.
Old Apr 19, 2005 | 10:30 PM
  #34
bert's Avatar
bigge did you check grapewood frame in grand rapids I had the same problem with my 02 two much angle I ended up just going back to stock now I have an 05 cant decide on what lift
Old Apr 20, 2005 | 01:27 AM
  #35
ryans05's Avatar
i put a 6 in super lift on my 05 had a vibe the fix was transfer case drope bracket and realingment fix it. not more vides. hope that helps
Old Apr 20, 2005 | 02:45 PM
  #36
Patrolman808's Avatar
I'm done with Superlift, that's for sure. There were a few things I didn't like about mine, but the driveshaft angle on the front was the worst. Nothing like having a useless 4wd dually with 9" of lift and 35's and having to run w/o a front driveshaft.
Old Apr 21, 2005 | 09:55 PM
  #37
red rock's Avatar
I just put a 6" superlift kit on mine with 36" Mickey MTZ's and haven't had any vibe. The ride is just as good as when it was stock.
roughstock
Nov 2, 2013 01:48 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
VikingDiesel
47
May 11, 2007 12:52 AM
Hemlockusa
Jan 28, 2006 07:07 AM
