4" downpipe for 03
Old Feb 9, 2007 | 12:06 AM
RedRam410's Avatar
4" downpipe for 03
I think im just gona go with a 4" downpipe and a 6 inch tip for now instead of a 5" exhaust.. anyone know where i could find a 4" downpipe??
Old Feb 9, 2007 | 03:56 AM
Dodgezilla's Avatar
I got one from DPP when I had my 03SO. It's from Banks and replaces the DP and the turbo elbow. It ran me about $200.00. Pretty expensive!! Try to find a newer 4" in/out elbow and DP from a newer truck...
Old Feb 9, 2007 | 05:41 AM
Luvnacumns's Avatar
I have the stock DP from my 4" system I took off my truck when I went to the 5" system. IF you want it PM me.
Shane
Old Feb 9, 2007 | 08:29 AM
RedRam410's Avatar
Will it fit on a 03? what else would i need
Old Feb 9, 2007 | 08:44 AM
Luvnacumns's Avatar
I am not sure if it will bolt up to an 03 or if you need an elbow? Do a little research and let me know..
Shane
Old Feb 9, 2007 | 09:03 AM
Dodgezilla's Avatar
You will need the newer elbow and one 4" V-Clamp.
Old Feb 9, 2007 | 09:05 AM
RedRam410's Avatar
Where would be the best place to find that elbow?? will this make my truck louder like the 06
Old Feb 9, 2007 | 11:41 AM
Dodgezilla's Avatar
You can find them on E-Bay sometimes. The dealer has them too. I got lower egts but also a bit of drone when I changed mine out. It probably won't make it any louder unless you are also adding a HP muffler. If you are going to keep the factory tailpipe you will have to cut a couple inches off of it where it connects to the muffler. It's only 3.5" there but flares out to 4" after a couple inches...
Old Feb 9, 2007 | 07:59 PM
ksram's Avatar
If you have a local Cummins dealer price will be alot less and they can match the clamp if you take your elbow in. I changed my 03 4-3.5 elbow to a 4-4 elbow off of an 04 and then followed with a 5 inch turbo back expandit exhaust. The truck sounds very quite with hardly any pressure at tail pipe, with the truxedo tonneau I'm pulling 25 mpg as long as I stay under 2000 RPM. I'm running Edge EZ but might upgrade, it is only at stage 2 not ever put it on stage 4 yet. Local Cummins dealer much less than dealers.
Old Feb 9, 2007 | 09:18 PM
JJ's CTD's Avatar
Hey ksram, do you remember the part numbers at Cummins for the elbow and downpipe? I've got the Dodge p/n for that stuff and the cheapest I can get tham is about $120 total. Is buying that stuff from Cummins that much cheaper?
Thanks
JJ
jdinny
0
Sep 28, 2012 08:00 AM
97catintenn
Jul 12, 2009 05:33 PM
colonialcobra
Feb 14, 2008 03:31 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
