35X12.5 R17 BFG M/T's and towing?
Ok, I think I have decided on the BFG's 35X12.5 R17, I have a few questions...
1. Will they fit on my stock truck with stock rims? (I can handle a little rub)
2. Will the width of the tire on the stock rim make them wear fast?
3. How will my truck tow compared to stock with the 35's and my exhilartor and BHAF and straight pipe? I tow about 15,000lb 30% of my miles. and 3800lb 35% so i need it to tow atleast as good as stock but with the chip.
I wish BFG made a 305 in the M/T, if those wont work, how will the 315 A/T work? I can get some 305 buckshots for $720 or the 35 BFG M/T's for $1150
315's no leveling kit! Tow great a little softer than the toyo mt's but not bad rub's a little on the inside control arm. They will fit just fine on stock rim's. I just put on Ultra's New Mako rim and they just barely rub the 1/8 bottom of the air dam will have to trim just a hair..
Shane
Shane
i had the them before I went to the 37s. They were fine. Had them on for 22K and issues. I dont tow that heavy though about 5K.
I have pics. well I guess most people have seen them.
I've been running 35" bfg for a long time without problems. Had them on stock rims for a year with 2 in leveling kit before lifting and going to aftermarket wheels. I tow 4500lb bass boat all the time without a single problem, often with 1500lbs in bed when on trips. Smooth on highway. I run 45lbs in front tires and 42lbs in rear. Have worn good too considering how I drive and being on a diesel 3/4 tread with 16000 miles on them.
Rednecktastic
Feb 15, 2009 11:13 PM
silkywoods
Sep 8, 2007 12:53 PM
checkster
22
Jun 3, 2007 11:41 PM
HorseHauler
19
Jan 23, 2005 11:31 PM
) of the E-rated Open Country
