21 lbs boost??
Old Feb 6, 2008 | 08:12 PM
jtskir222's Avatar
21 lbs boost??
hi guys
i have a 05 2500 with the bullydog triple set up, afe air intake dual exhaust 5 inch and an auto tranny semi worked.
question is.. i only get 21 max reading for boost even on the crazy eddy setting.... is this correct.. been like this since i set it up a few years ago.. but i am reading guys getting 38 or even 40 on the stock turbo?? what do i have to do to mine to get it to kick up a notch...??
thanks in advance..
mark
ps- what would be a good choice if i wanted to upgrade the turbo.... nothing to crazy its a daily driver.. and is it bolt up to the exhaust and air intake? not looking to change it all again..
thanks
Old Feb 6, 2008 | 08:48 PM
Big E diesel's Avatar
no, you should be getting way more pounds of boost than that. i get about 38 with my stock turbo
Old Feb 6, 2008 | 08:56 PM
shortbed rv's Avatar
I believe the stock 05 gets about 32 psi boost and with any boost fooling about 40. You May have a leak. Check your intercooler and see if it has plastic end caps for a possible leak. For a time somewhere during 05 Dodge tried the plastic end caps vs metal. The plastic caps have been known to leak.
good luck
Old Feb 6, 2008 | 09:13 PM
06CTDforAU's Avatar
Originally Posted by jtskir222
hi guys
thanks in advance..
mark
thanks
How are you getting the reading? Outlook, gauges? Do you have a boost fooler installed? I'm guessing you are talking about the Crazy Larry setting. Never heard of Crazy Eddy; maybe it's some kind of secret tune.
Old Feb 7, 2008 | 04:25 AM
chipmonk's Avatar
i bet he's from n.y.- there was a big electronics chain in n.y. many years ago called crazy eddie.
Old Feb 7, 2008 | 04:50 AM
Kman9090's Avatar
If it's on the PMT I've heard of a few of those reading incorrectly.
Old Feb 7, 2008 | 08:14 AM
cincydiesel's Avatar
Dang another 05 with boost problems!!! Man I've seen more threads with 04.5 and 05 (including my own) with boost problems than I care to see. I clamped off the rubber hose leading to the wastegate and cured my problem. Electronic actuator for the wastegate died on mine. I think the boost fooling done by the Edge killed it.
Old Feb 7, 2008 | 09:02 PM
CLeger67's Avatar
If your getting Outlooks reading, I was showing 24psi and occasionally 28psi. I installed an analog and am actually getting 32psi and as high as 40psi . Even at 10psi from outlook my analog reads 15psi. Boost fooler shows even lower Outlook numbers.
Old Feb 7, 2008 | 09:08 PM
CLeger67's Avatar
dieselnewbie
Jul 11, 2005 04:40 PM
KATOOM
Mar 22, 2005 11:15 AM
eng208
Jun 14, 2004 01:33 PM
misterKTM
Nov 23, 2003 12:39 AM
JImbo1
Aug 27, 2003 08:13 AM
