2004 dodge 2500
Old May 19, 2010 | 07:38 AM
mickey4353's Avatar
2004 dodge 2500
I have a 2004 dodge 2500 ctd 4x4 auto tranny quad cab. Iam tring to fifgure out which engine i might have ive done some research and found 2 engines were installed that year maybe 3 my valve cover says 305 hp but i dont know if thats the smaller or larger, the 2004.5 have 325 hp what iam tring to find out is my towing capacity and the gcvwr of both trailer and truck i have 3.73
Old May 19, 2010 | 08:14 AM
AlCorr's Avatar
Go to this link:
http://www.dodge.com/towing/D/vehicle_to_weight.jsp
At the top of the page, center, put the year of your truck, then check your truck (2500) then go down the line and answer all the questions, your engine is not the 610 diesel (last 2 at the bottom of list).
Check it out, it's easy, even I can do it!
Old May 19, 2010 | 08:33 AM
AlCorr's Avatar
2004 dodge ram heavy duty pickup 2500 SLT, QUAD CAB, 4WD, 6.25 FT Bed, 4-Speed Automatic Transmission, 5.9L 24V Cummins Turbo Diesel Engine:
With 3.73 Axle Ratio Axle Ratio [i] You Can Tow 10000 lbs
Gross Vehicle Weight Rating (GVWR) [i] = 9000 lbs
Payload [i] = 2140 lbs
Curb Weight [i] = 6860 lbs
Curb Weight Front/Rear = 4161 lbs/4161 lbs
GAWR Front/Rear [i] = 5200 lbs/6000 lbs
Gross Combination Weight Rating (GCWR) [i] = 17000 lbs
Old May 19, 2010 | 09:15 AM
mickey4353's Avatar
dodge
How do we know its not the last 2 just asking
Old May 19, 2010 | 09:25 AM
soulezoo's Avatar
DTR 1st Sergeant
Because you have a 305 engine (2004) vs a 325 engine (04.5).
Old May 19, 2010 | 09:45 AM
AlCorr's Avatar
Yes, what he said, the 610 is really the 2005 year engine, but in late 2004 for what ever reason, Dodge started putting the 2005 engines in the 2004, (2004.5) but didn't give them the full 610 lb only 600 lb.
Old May 19, 2010 | 09:53 AM
AlCorr's Avatar
Is the 305 hp, the "SO" (Standard Output) or the "HO" (High Output) engine? Or is that only in 2003 when they had two different engines?
Old May 19, 2010 | 10:03 AM
DieselResearch's Avatar
That's a cool link
Old May 19, 2010 | 10:45 AM
mickey4353's Avatar
dodge
http://dodgeram.info/2004/load-tow/2500.html
if you look at this link and i have the HO then iam lookin at 20,000 iam just ruling out all resources
Old May 19, 2010 | 12:03 PM
AlCorr's Avatar
Now that's what they call "wishful thinking"
Old May 19, 2010 | 01:29 PM
soulezoo's Avatar
DTR 1st Sergeant
The 305 is the HO engine. 235 and 250hp was the SO engine.
After 04.5 and the 325hp engines, the HO and SO was dropped.
Old May 19, 2010 | 01:56 PM
mickey4353's Avatar
dodge
Alcorr where are you getting the info at? if its the ho then am i correct in 20,000
Old May 20, 2010 | 05:19 AM
AlCorr's Avatar
I maybe wrong, but this is what I found.
Old May 20, 2010 | 05:23 AM
AlCorr's Avatar
http://www.dodge.com/towing/D/vehicl...c+Transmission
This is the link to the page, only trying to help you out, you can call it a 30,000 lbs GCWR if you want, this is the information you asked for.
Old May 20, 2010 | 08:09 AM
rufushusky's Avatar
The HO lasted from 2003-2004 and was 305/555..aka the triple nickle.
In 2003 there were three engines
CA special 235/460
SO 250/460
HO 305/555
In 2004 they dropped the CA and on January 4th 2004 the 325hp or 600 series engines showed up. If you valve cover says 305 you have a 2004, not 2004.5 engine.
