2004 with Crankcase breather canister leaking
Old Feb 24, 2011 | 10:43 AM
pmiz05's Avatar
I have a stock 2004 cummins made before july 04. I believe it is the Crankcase breather canister on top of the motor. Small black box that goes back into the crankcase. It is leaking oil from the return line. Does this have a filter inside of it, and if so how do I get it apart? If no filter where can I find this part to replace it? Both lines going to the canister are in good shape so I don't believe the leak is coming from either of them.
Old Feb 24, 2011 | 11:23 AM
pmiz05's Avatar
Also heard of this being called a blow bye filter???
Old Feb 24, 2011 | 11:58 AM
JJPage's Avatar
Yes, I am sure I have read threads about removing and cleaning @ 80k intervals. I am not there yet, but I would think a cleaning solvent or airfilter cleaner or Simple Green would work. IIRC it is a steel mesh filter.
Old Feb 24, 2011 | 11:59 AM
JJPage's Avatar
If you have excessive blow by, a clean filter may leak worse...
Old Feb 24, 2011 | 12:44 PM
ripping r's Avatar
here is the place to get the new filter.
http://www.genosgarage.com/prodinfo.asp?number=3957987
Old Feb 25, 2011 | 06:31 AM
Dodgezilla's Avatar
I recently pulled mine off and cleaned it the best I could with some Carb Cleaner. Then I hit it with compressed air to dry it out. The problem is that it's a sealed unit and you really cannot see the filter at all. I just got a bunch of cleaner inside it and plugged all the holes then shook it violently. Mine had been leaking too and after about two weeks I do not see any visible signs that it is still leaking. I have not pulled the valve cover off though to verify this. Before, the oil was coming out around the bottom of the valve cover.....
Old Feb 25, 2011 | 01:49 PM
jhenson's Avatar
Mines never been cleaned in almost 300k miles. No leaks out of it so I don't worry too much about it.
Crap.....I better go pop the hood and check it now that I said that .
Old Feb 25, 2011 | 09:30 PM
pmiz05's Avatar
Thank you for all the help. It's a minor leak, but very frustrating espically since this is my first diesel!
jimbo486
Jun 28, 2012 09:13 PM
Jmac
Sep 3, 2010 07:31 PM
4x4BOB
16
Feb 5, 2010 06:29 PM
silverram323
Aug 15, 2003 06:21 PM
