2003 - 2005 Jake Brake
Old Nov 20, 2005 | 11:04 AM
Hemlockusa's Avatar
I would appreciate your input on a Jake Brake, what are they worth and how much does it cost to install? Or can it be installed without taking it to a garage??
Is there a lot of market for Jake Brake's?
Thanks John H
Old Nov 20, 2005 | 06:56 PM
J&L's Avatar
J&L
John
there is no "Jake" brakes for our Cummins. A "Jake" goes in the big rigs engine internal in the exhaust side of the valve train to help slow the rig down. Jacobs makes a exhaust brake that works very good for our Cummins. It goes in the exhaust behind the turbo. Check out jacobs.com web/pacbrake.com web/ bd-power.com web/ bankspower.com web for info and prices. If your buying a new truck get the Jacobs exhaust brake and it has a Dodge warranty.
I have a Jacobs on my Dodge with the 6spd tranny. Perfect tow vehicle that puts the brake on my 11200 lb 5er comming down long steep grades in the mountains or just daily use.......JIM
Old Nov 23, 2005 | 02:34 PM
Patrolman808's Avatar
Actually, they're just called a Jake brake because Jacobs makes them. Two different setups though. The one for the 3/4 and 1-tons uses a butterfly valve on the exhaust pipe, the one on the big trucks opens the exhaust valves around TDC compression stroke. No compression, no ignition, no power stroke.
Old Nov 23, 2005 | 04:22 PM
Hemlockusa's Avatar
I WANT TO THANK EVERYONE FOR RESPONDING, I MENT EXHAUST BRAKE, JAKE BRAKEJUST CAME OUT. THE REASON I ASKED THERE WAS ONE ON E BAY UNOPENED AND THE BID WAS ABOUT 200 dollars BUT THEN I LOOKED AND IT WAS COMPLETE BUT FOR A MANUAL TRANS. I THANK EVERYONE FOR TRYING TO HELP THIS OLD MAN OUT.... SEE YOU DOWN THE ROAD JOHN H
Old Nov 23, 2005 | 05:33 PM
rammtuff's Avatar
Unless you have an '06 I don't think DC wants you to put an exhaust brake on an automatic. But for a hand shaker they are one of the best options you could spend your hard earned money on. If you are mechanically inclined self install is fine. Expect to pay around a grand give or take.
Old Nov 23, 2005 | 08:10 PM
Jeff in TD's Avatar
You can go over to www.jakebrake.com and under the support tab you can download the installation instructions.
I did mine myself, and it was pretty straight forward. I don't know anything about the install on the auto, though.
Old Nov 24, 2005 | 07:47 AM
JD 70's Avatar
a true jake would be an awesome addition to our mini roadtractors...why doesnt anyone make one...what would be involved...would it be too expensive?
wvcowhauler
13
Apr 3, 2005 11:39 PM
shortround
Feb 5, 2005 08:40 AM
rvlady
Sep 8, 2003 06:27 PM
