2" Leveling kit- Does it need alignment
Old Feb 25, 2006 | 09:26 AM
dwhite's Avatar
Do you have to have an alignment done after installing 2" coil spring spacers? I know alot of manufacturers say to have it done but is it just to cover their...behind or does it really need to be done. Seems like not alot would change with just a spacer but I dont know.
Old Feb 25, 2006 | 09:30 AM
PimpRohr's Avatar
I just did mine and had it checked out but it didn't really need any major adjustment. I just fine tuned it to make up for the change in hieght.
Old Feb 25, 2006 | 09:52 AM
dwhite's Avatar
Was it pretty simple to do? I have some 2" hell bent steel spacers on the way.
Old Feb 25, 2006 | 09:57 AM
PimpRohr's Avatar
It was VERY simple to install. Just a few bolts, a jackstand, a jack, and some elbow grease.
Old Feb 25, 2006 | 12:12 PM
mkinla's Avatar
NO, you do NOT need an alignment with just a 2 inch spacer.....
Old Feb 25, 2006 | 03:52 PM
TexasCTD's Avatar
The instructions you will receive with your HBS leveling kit will tell you to go get it aligned. Mine wasn't off by much, but I went ahead and had it done anyway. I think it was like $59.00 at the dealer. I had just installed the new BFG's the same day too so I wanted to make sure it was all true.
Old Feb 25, 2006 | 04:47 PM
01350banshee's Avatar
Although I have a 2wd, anytime you unbolt front end components like ball joints etc.. you should have it checked when done. I just installed a 1.5" lift last Friday, took it in Saturday and caster/camber was off by quite a bit.
https://www.dieseltruckresource.com/...ad.php?t=92776
Old Feb 25, 2006 | 06:26 PM
WSnyder's Avatar
Toe in and caster will both increase. I would be more concerned with the increased toe in and wouldn't worry much about the caster increase.
Old Feb 25, 2006 | 06:36 PM
BKCBUILDER's Avatar
I put mine on within 500 miles of brand new, and the alignment was off and needed corrected. It drove fine and tracked straight, but was off considerably. Possibly from the factory....but I doubt it.
Old Feb 25, 2006 | 07:45 PM
mkinla's Avatar
When did the cummins come with IFS.....?
Old Feb 25, 2006 | 07:58 PM
no_6_oh_no's Avatar
Doesn't have anything to do with IFS. Cummins is an engine not a vehicle, doesn't have caster.
ALWAYS align after a height change. Caster and toe in will change.
Old Feb 25, 2006 | 08:04 PM
When you drive a 2wd as some of us do.
Old Feb 25, 2006 | 08:19 PM
gerry's Avatar
Mine drove straight after the 2 inch spacers but I had it checked anyway.
They found it to be out by a little bit.. The front end guy said it is not uncommon for it to be out from the factory. They have a jig they drive the truck onto and set the front ends.. the jig is only adjusted and recalibrated about every 50 trucks so it is not unusual for the alingment to be off from the factory.
Gerry
Old Feb 25, 2006 | 08:21 PM
mkinla's Avatar
Oh man sonfroma...... Sorry guys my bad......
Old Feb 25, 2006 | 08:28 PM
Now drop and give me 20 push ups.
