18"X9" with 4.5 backspacing will it work?
i have an 03 2500 quadcab 4X4
i ordered a set of 18X9 with 4.5 bs, the salesman assured me they would work on the stock suspension, with no leveling kit required
i was going to run 285/65/r18
i dont want to lift the truck, but from what im reading on these forums, i may have seriously goofed
will this setup work?
i have ordered ats fender flares, and wanted to fill them up
i want the oversized wheel and tire look without the hassle
the wheel i ordered is the 1091 series American racing cannon
it is available in 5 and 1/4 backspacing, would this work better?
any help or pointers would be GREATLY appreciated
otherwise i may be fighting with the salesman
Yep 4.5" will definately rub. I hate it when all these sales people try to push wheels with 4.5" backspacing on customers. I guess they think all of us want 12" of lift and 40's. You would be much better off with the 5.25" backspacing and it would still fill up your flares pretty nicely.
if it does rub, will it be so slight that a leveling kit up front will negate it?
and will this backspacing cause my ball joints to wear out faster?
im gonna try to stop the order and swap to the 5.25 bs, but...
depends on the salesman i guess
with the 5.25 bs could i go with a larger tire? 305/60/18?
i asked all the tire shops around where i live and they all said my current setup would work...man oh man i wish i had found these forums b4 tonight
tks for all the input guys
i also missed the part about it being available in the 5.25...you'd be much better off with that. but i still think you'll be fine with the other. try them out and since the salesman guaranteed you won't rub, make him swap them if they do!!
i used to run a 33x12.50x17 mtz on a 17x9 moto wheel, with 4.53" b/s with ats flares before i had any lift, and i had no rubbing issues. if you run a 33" tire on wheels with near stock b/s, you might find that your ats fender flares will look kinda silly, as your set-up will not stick out from your fenders, then you'll have about 2 1/2" of flare with no tire under it.
That's right the ATS flares would look a little silly with narrow wheels/tires, but if he runs the wheel with 5.25" backspacing on a 12.5" wide tire or so, it would look fine in my opinion. My 9" wide wheels have 5" of backspacing and the tires sit level with the flares (if not just a hair outside of them) and it looks great.
Absolutely correct, been there.
