12x1.75 tap for studs...?
If it were only that easy... $$$
Someday springs and a cam will come but not now... My headgasket is tip-top. No need to mess with it currently, and hopefully not in the future..
Jeff K, I ordered the tap as it is the only one I can find that is long enough.. or we shall see...
Well, I have a telescopic magnet tipped pen-like device, and 2 shop-vacs. If that won't do it maybe I can get a streetwalker who has great oral skills to give me a hand, or a mouth...
Seriously, I'll have the tap tomorrow as the supply house is half and hour from me, but now I just have to schedule around 8hrs to git-r-done...
pourin says pull the head. If I pull the head I want to send it off. dont have the funds for that right now.
You don't need to pull the head. You can do it with a regular tap if you grind the end off and use a socket and a long extention. Also the telescoping magnet works great for removing shavings. Just take you time and oil the tap and run it in and out a few times. I had the correct tap and still found it easier to use 1/4" drive rachet and an extention and a standard length tap. Tap handles are great if there isn't a lot of crap in the way (firewall).
Thanks
