12.60 @ 108mph
DTR Advertiser
12.60 @ 108mph
Went to Richmond raceway last night for some testing and got 4 runs in. I went 12.85 with just a Bullydog cl 2.2.7. I cant use the newer cl with torq management delete for some reason it sets codes on mine, so this was with torque management on. Next I added the tst on 3/1 but it rattled in 3rd and 4th gear bad so I backed out of it some on top end. It still went faster at 12.60 at 108 but I didnt want run it with the tst till I get the adjustable timing version. Last run was with the cl and Don Ms small press box set at about 1/2 way and it went 12.63 and no rattle or miss. All launches were with 14-15 lbs of boost. It has a lot more in it but I have some good base lines. Tim
DTR Advertiser
I have some videos of it, I will have to have a guy from work post it though. I am not real good with computers. Good luck at the rock Mike. I had another guy with a 06 there that went 13.50 with just a dtt trans, crazy larry, afe stage 1 and a htb2/12. He was only launching at 2 lbs of boost due to a stock output shaft. That will be fixed this week. I will have some flux 3s in mine this week so I will try to get to the track again in 2 fridays. Running just the cl and press box my egts never touched 1400 so that turbo is really moving air. Tim
nobody
32
11-30-2006 03:12 PM
