100% Bolt-On Turbo Upgrades.....
Old Aug 8, 2008 | 08:26 PM
D45's Avatar
D45
Just curious, but with the stock exhaust manifold, are there 100%, no fuss, bolt-on aftermarket turbo upgrades for a dailly driver?
If so, what is out there?
Would I have to upgrade my fuel delivery system, from the dealer installed retro-fit intank system?
I may need a winter project, and might start saving up for a turbo, and possibly an aftermarket exhaust manifold.......
Old Aug 8, 2008 | 08:27 PM
wap's Avatar
wap
Most all of the common turbo swaps are a direct bolt on.
Old Aug 8, 2008 | 08:44 PM
D45's Avatar
D45
Really...........I was not aware it was that easy, to bolt on that much more power!
Industrial Injection makes the original PhatShaft, that is said to be the "perfect upgrade turbo for towing". I tow maybe 1-2 times per month, and not competitive towing, just towing a 20" deep-v Lake Michigan fishing boat.
-PhatShaft is available in 2 different compressor sizes, 62mm and 66mm.
"PhatShaft 66 is a mid to high range turbo upgrade intended for performance and light towing."
"The PhatShaft 62 is the perfect upgrade turbo for towing"
BD's Power Super B Single sounds nice.....
"yet are responsive and durable enough for street and heavy towing applications"
Featuring BorgWarner’s unique Extended Tip compressor wheel technology and low inertia, full-floating journal bearings, these turbos utilize BD’s unique dual-volute turbine housing. This proven design utilizes low rpm exhaust pulses for improved turbine response, while the dual-action waste gate bleeds off turbine drive pressure from both volutes. BD's turbo systems also feature a heavy-duty waste gate actuator that prevents pre-mature opening caused by high exhaust pressure. You can even fine-tune your BD/AirWerks turbo for ambient temperature and barometric pressure changes using BD’s adjustable waste gate control.
If I do upgrade and get a new turbo, I would hope to spend $1300-$1600.
Any ideas what else I should look for, or what turbo would be a good overall performance and towing upgrade for my truck?
Old Aug 8, 2008 | 09:10 PM
rip 112's Avatar
I use my stock exhaust manifold with my HTT, works great. An aftermarket manifold would work better though.
Old Aug 8, 2008 | 09:16 PM
cincydiesel's Avatar
Does the aftermarket manifold help build higher boost levels?
Old Aug 8, 2008 | 09:31 PM
rip 112's Avatar
Yes definitely. It'll quicken spool time and seems to help get an extra pound or 2 of pressure. Better flow.
Old Aug 8, 2008 | 10:12 PM
Lightman46's Avatar
[QUOTE=D45;2171681]Really...........I was not aware it was that easy, to bolt on that much more power!
Turbos in and of them selfs do not increase HP they give you more air so you can add more fuel and the fuel gives you more power.
Old Aug 9, 2008 | 12:08 AM
SlowSixSpeed's Avatar
^ X2
Old Aug 13, 2008 | 05:44 PM
D45's Avatar
D45
Anyone running a Super B turbo on a stock truck, with stock fuel system?
Old Aug 13, 2008 | 05:49 PM
Hintz's Avatar
FYI better flow should drop PSI, PSI is also a measure of restriction. Thats why if you port the heads, intake and exhaust PSI will drop quite a bit, but power will still go up. More volume, but less restriction
Old Aug 13, 2008 | 05:52 PM
rip 112's Avatar
Gotcha hintz, wasn't thinking the other day.....
Old Aug 13, 2008 | 06:07 PM
Ridiculies's Avatar
I'm runnin the Super B, not sure what you mean by stock truck. But my fuel system is stock.
Old Aug 13, 2008 | 06:12 PM
D45's Avatar
D45
Yes, I meant a stock fuel system......
Why did you choose the Super B?
Did you notice anything, good or bad, after it was installed?
Are you pleased with it?
FordTrax
Apr 18, 2014 08:47 PM
53 willys
38
Nov 6, 2008 11:18 AM
StrokeThisCTD
Jun 17, 2006 08:28 PM
mcevins
Jan 3, 2005 03:23 PM
