07 megawith electrical failure !!!
Old Jan 6, 2010 | 03:56 PM
genros's Avatar
Satruday morning had lil power, not enough to make the engine turn
i trickle charged the batteries and had everything workn great sunday
monday turned the engine over and died. I jumped it and hit the alterator with a meter. Everything working correctly.
Tuesday drivn 30 mintues to work watched the voltage meter slowly decrease in the truck. got a block from work and putted in. hit it with meter 8amps!!!!!!dead
trickled batteries overnight, passenger side had acid all over the top and drivers side was smokn. Ordered a new alternator and installed two new interstate batteries.
Do you think there was a trigger? Something that fired off the chain reaction
Old Jan 6, 2010 | 04:14 PM
Ramified5.9's Avatar
Did you have your alternator bench tested? I had a similar situation on my '05, and the alternator was fine, but the batteries were toast causing all kinds of electrical problems.
Old Jan 6, 2010 | 04:44 PM
genros's Avatar
I will attempt to get it bench tested id like to know if i am wasting money
IPDiesel
Jul 29, 2015 09:57 PM
dodgetrucker75
Mar 17, 2011 09:15 PM
quantrill88
Mar 19, 2003 05:04 PM
Map70
Mar 18, 2003 08:19 AM
Rigg4x4
Nov 23, 2002 06:42 PM
