Hydraulic Pump Failure?
Old Mar 17, 2003 | 09:26 PM
Map70's Avatar
Was driving across I-80 in PA (450 miles on truck) when I noticed the steering get VERY heavy. I signalled, began pulling over and then lost break assist. Upon inspection I found that the clamps were never correctly installed on the 2 hydraulic lines going into the cooler, and one line had completely fallen off effectively draining all of my power steering fluid.<br><br>I was on a pretty dangerous section of road (no shoulder) so I decided to drive to the next exit. Found some fluid, refilled and everything seems fine know.<br><br>My question is: Would driving around 5-10 miles with the system empty damage to pump or any other components?<br>
Old Mar 18, 2003 | 08:19 AM
spots's Avatar
Re:Hydraulic Pump Failure?
Should not damage it. Usually if a powersteering pump starts to die it will whine loudly. Bring it to the dealers attention, so it is noted on the work order if a future failure does occur. Sometimes takes time to get the air outa the system, pump will be loud for a bit. Clamps shoulda been picked up on the PDI.
IPDiesel
Jul 29, 2015 09:57 PM
jesussaves
Jun 28, 2012 01:36 PM
dodgetrucker75
Mar 17, 2011 09:15 PM
AMT
Mar 13, 2006 02:49 PM
spitzair
Dec 27, 2003 05:21 PM
