07 camber question?
Old Sep 30, 2008 | 05:53 PM
mulisha's Avatar
07 camber question?
guys, im trying to address a death wobble problem, only when im at the track, anyway one of the issue's was to adjust the camber, thats my question, can it be done on an 07, cause i dont see where, thanks
Old Sep 30, 2008 | 07:01 PM
jlibert's Avatar
camber not adjustable unless you go with aftermarket ball joints. Caster is adjustable with the eccentric bolts on the front of your lower control arms.
Old Sep 30, 2008 | 07:03 PM
mikmaze's Avatar
tossing this out here to try to help, max negative caster is what we are usually after to help cure death wobble ? lots of threads to search throuh, a simple answer here could help out a lot, thanks.
Old Sep 30, 2008 | 10:40 PM
triplenickel's Avatar
On the front of the lower control arm, adjust the eccentric (washer with a hole off center) so that the fattest part is against the stop.
Brian.B
Oct 5, 2012 11:55 PM
xp8103
Nov 8, 2004 10:59 AM
Puke
Jul 23, 2003 01:07 PM
dma251
Jun 19, 2003 04:17 AM
