cast and camber question,,,
Old Sep 30, 2012 | 12:09 PM
Brian.B's Avatar
i had my upper king pins redone and the mechanic said there not adjustable,,the passenger wheel was dead on but the driverside still leans out,,,how can i fix this,,,,any help will be appreciated,,
Old Sep 30, 2012 | 12:23 PM
BILTIT's Avatar
Maybe the lower kingpin/bearing is wore? Wheel bearings in good shape and tight?
Camber isn't something that is usually needed to be adjusted with these front ends. You can buy adjustable lower kingpins but should not be needed.
Old Sep 30, 2012 | 12:31 PM
Brian.B's Avatar
everything is tight,,cant you adjust the plastic cone piece,,or get one with a different offset or something...
Old Sep 30, 2012 | 03:12 PM
BILTIT's Avatar
You cannot adjust the plastic cone. Have you checked to see if the spindle is bent?
You can get shims to adjust the spindle angle in relation to the knuckle.
Here is the adjustable lower kinpin:
http://www.ebay.com/itm/DANA-60-FRON...-/120980565406
Did the mechanic replace the upper kingpins themselves or just the plastic bushings? Could be the upper kingpins are worn and need to be replaced.
Old Oct 4, 2012 | 08:42 PM
Brian.B's Avatar
are you sure thats the lower,,i thought the lower was a bearing,,that looks more like a top ford kingpin
Old Oct 4, 2012 | 10:46 PM
BILTIT's Avatar
Yes its the lower. This is the stock lower kingpin which the bearing is mounted too.
http://www.partsmike.com/store/store...on=show_detail
You can see it better in a breakdown of the complete diff.
http://www.pirate4x4.com/tech/billav...pin/index.html
Old Oct 5, 2012 | 11:55 PM
rebal's Avatar
This is what I used , my 90 was so far out (from factory)I had to get it to 3/4+ to get it in spec.using the adjustable lower bearing kit was not enough and when I would pound the truck down real bad roads the adjustable upper nylon bushing kept moving out of position
Dana 60F camber shim reference
MOOG Part # K9803
adjustment range from -3/8 to +3/8 Deg.
MOOG Part # K9804
adjustment range from -1/2 to +1/2 Deg.
MOOG Part # K9805
adjustment range from -5/8 to +5/8 Deg.
MOOG Part # K9806
adjustment range from -3/4 to +3/4 Deg.
MOOG Part # K9807
adjustment range from -7/8 to +7/8 Deg.
MOOG Part # K9808
adjustment range from -1 to +1 Deg.
MOOG Part # K9809
adjustment range from -1-1/8 to +1-1/8 Deg.
MOOG Part # K98010
adjustment range from -1-1/4 to +1-1/4 Deg.
MOOG Part # K98012
adjustment range from -1-1/2 to +1-1/2 Deg.
http://www.mypartsgarage.com/media/c...age_202578.jpg
caster was set with a wedge under the springs
TX_Diesel
Aug 21, 2011 09:40 PM
sotex
Jul 30, 2010 10:32 PM
mulisha
Sep 30, 2008 10:40 PM
dma251
Jun 19, 2003 04:17 AM
