06 edge problem?
Old Sep 9, 2006 | 01:46 PM
3500Singlewheel's Avatar
Originally Posted by tdm
Don't bother with the dealer. You stated that when you removed the wiring harness and box that all was good, right???
This means you have a problem with the box not the truck! The dealer won't be able to help you at all...... except with the voiding of your warranty of course
from what the guy at edge told me they have a 06 dually that had a similar problem, everytime they took the box out it would go back to normal and they said it was a clogged injector causing the problem. I didn't really understand how if the injector was cloggged, it was fine with the box out.
what do i try next? back to bullydog?
Old Sep 9, 2006 | 01:57 PM
tdm's Avatar
tdm
BOY.... I don't know about that. I would think that an injector that was that bad would also show some issues in the stock setting. Plus one completely shot injector shouldn't make the truck "buck" heavily like you describe.
Just as a "what the heck" you could run some injector cleaner through the truck and see if you notice any change. You could also hook up to the heaviest trailer you can and find a big hill. If you have an injector issue you'll definately feel it while pulling heavy.
Old Sep 9, 2006 | 03:31 PM
it does have a little weird knock when in gear, but other then that it runs fine and only has 700 miles on it.
Old Sep 10, 2006 | 11:40 AM
m2fsr's Avatar
She was built in November 05, installed the edge just over a month ago.
Old Sep 10, 2006 | 11:56 AM
moltred's Avatar
I recently had problems with my Edge J/A. To make a long story short, my coolant level was low.I filled the resevoir up to where it should be,plugged the juice back in.All is good now.I think sensors were playing havoc with the juice.I hope this helps.good luck.
curts99
Dec 12, 2006 07:44 PM
rockjeep73
Mar 25, 2005 03:34 AM
Hoss
13
Jun 18, 2004 06:14 PM
powerwagon440
Jan 20, 2003 08:50 PM
