06 edge problem?
Old Sep 5, 2006 | 11:09 PM
3500Singlewheel's Avatar
06 edge problem?
sup guys,
just installed a edge attitude w/ juice, on the first test drive i noticed the truck bucking really bad & pinging like crazy as I got on the gas. Tried all of the programs even 0 which is stock, same thing. Checked over the install on every harness could not find anything wrong. I just unpluged the injector harness and map sensor put back to stock and it was back to normal Anyone else ran into this problem?
Old Sep 7, 2006 | 10:39 AM
to the top
Old Sep 7, 2006 | 10:43 AM
JD Dearden's Avatar
Ya my buddy had to send his back to Edge.
Old Sep 8, 2006 | 12:27 AM
same problem? pinging? they said they are on back order on them. anyone with a 06 have one working good??
Old Sep 8, 2006 | 12:51 AM
mickey5978's Avatar
Same problems here. Waiting on new one. If it is not fixed this time, will head back to the superchip and gauges......
Old Sep 8, 2006 | 10:29 AM
got my new box today, and same thing
I really want this thing to work. I cant handle the gauges and so forth.
what could be the problem?
Old Sep 8, 2006 | 10:32 AM
justinp20012500's Avatar
They are having problems with the wire harness.
Replace the harness and you should be good to go.
Are you pulling any codes?
Old Sep 8, 2006 | 01:33 PM
just changed out the wire harness same thing, did get 1 code from the intake temp sensor with the new harness but it never came back.
Old Sep 8, 2006 | 02:21 PM
dlg449's Avatar
I couldn' be happier with mine. It's better than I expected.
Dave
Old Sep 8, 2006 | 03:04 PM
Dave
only thing i can think of its a late model 06 which might have something to do with it only 600 miles on it, just got off the phone with nate from edge he said something about a cloged injector maybe.
Old Sep 8, 2006 | 03:31 PM
m2fsr's Avatar
I have had mine installed for over a month now and have no issues with it what so ever.
Old Sep 8, 2006 | 06:23 PM
how new is your truck? guess i just have some bad luck.
Old Sep 9, 2006 | 06:05 AM
badcompany's Avatar
I have had mine installed for over a month now and have no issues with it what so ever. Truck runs really good.
Old Sep 9, 2006 | 01:11 PM
for the people that are having problem's. are they 100% same as mine? pinging on all programs even stock. debating on just taking it to the dealer for them to look at it with the edge box uninstalled of course. Think the dealer will give me **** about the egt probe?
Old Sep 9, 2006 | 01:27 PM
tdm's Avatar
tdm
Don't bother with the dealer. You stated that when you removed the wiring harness and box that all was good, right???
This means you have a problem with the box not the truck! The dealer won't be able to help you at all...... except with the voiding of your warranty of course
