06 Bully Dog Power Pup
Old Dec 18, 2006 | 04:08 PM
DODGE4X4's Avatar
I just ordered my Power Pup for my 06 (thank you DTR Store) but do not know if it will activate my High Idle feature. Does anyone know?
Old Dec 18, 2006 | 05:52 PM
aggieredneck12's Avatar
the high idle for the the auto's only. you cant run it with a 6 speed.
Old Dec 18, 2006 | 05:55 PM
MOJO1's Avatar
Check out the SEARCH on high idle some guys have figured it out.
Old Dec 18, 2006 | 06:27 PM
DODGE4X4's Avatar
I know how to make it work on my 6spd (the #22 pin on the ecm), will the pup turn it on? I am going to the dealer on Thursday to get my drivers side window replaced but would rather not have them do it.
Old Dec 18, 2006 | 07:16 PM
bigman's Avatar
The high idle works on my 06 6speed......
Old Dec 18, 2006 | 07:28 PM
CD in NM's Avatar
Have the dealer make sure it's turned on when you are in for your window work. If you were planning to install a PTO driven winch you would need this feature turned on. You can install a jumper wire into the ECM "B" plug pin 22/use ECM grounding bolt for other end. This will then make your G56 tranny'd truck capable of the high idle. You can control the rpm of the high idle with your cruise control on/off and accel/decel for up or down rpm's. Several of the programmers will turn it on also, someone here with the BD surely will answer your question.
CD
Old Dec 19, 2006 | 09:40 AM
Bud Kunz's Avatar
The Bully Dog Triple Dog has the high idle enable feature. I don't think the power pup does.
Old Dec 19, 2006 | 03:53 PM
MOJO1's Avatar
The Bullydog will not turn it on Dealer has to.
Rod meyer
Feb 23, 2005 10:55 PM
dodgedude361
Feb 14, 2005 11:59 AM
sawboywv1
Oct 14, 2004 10:38 PM
