Question on bully dog power pup
Old Feb 23, 2005 | 06:53 PM
Rod meyer's Avatar
I've tried to find answer on their site and elsewhere but can't find.
Is the bully dog power pup a duration timing or presure. both or what?
thanks Rod
Old Feb 23, 2005 | 07:53 PM
AK RAM's Avatar
The Tow mode is timing and duration only. The Performance mode and Extreme mode are timing, duration, and pressure....all three in varying amounts. I have an e-mail at home that explains how much of each on each level is used to make advertised power. I'll post those numbers later tonight when I can get to it.
Brian
Old Feb 23, 2005 | 08:04 PM
Rod meyer's Avatar
thanks Brian that would be a great help.
I just received a Ramifier which is a pressure box. I would like to stack them but wonder if that would make to much pressure? It would be good if you could turn off pressure on downloader but turn up duration and timing for performance mode.
Rod
Old Feb 23, 2005 | 09:01 PM
bhoeffner's Avatar
There are no individual adjustments on the pup outside of the program you choose to run. Had the pup stack with my Volumizer, which a pressure box and it worked great. I did have to keep it on the 50HP setting, because the 100 HP setting would create a high pressure issue with the pup. There are a couple of folks that have posted great results with the stack you are questioning. I think whitesport has those plus another stacked together. Yes three different boxes.
Old Feb 23, 2005 | 09:13 PM
Rod meyer's Avatar
dang, I was hoping to get more duration from the pup, all I really wanted was the timing and duration, don't know if the 50hp setting would be worth 500.00.
Old Feb 23, 2005 | 09:23 PM
bhoeffner's Avatar
I think you mis-understood. I ran the pup on the performance and extreme settings( it is awesome). Had to keep my Volumizer on the lower setting due to the amount of pressure the Volumizer creates. If I would have put the Volumizer in the higher setting and left the pup in performance or extreme I could have blew the pop off on the common rail.
Old Feb 23, 2005 | 10:55 PM
AK RAM's Avatar
Here you go:
"The 50hp tow mode adds timing and duration to make the gain, no pressure. On
90 hp performance setting it adds 30hp worth of pressure and an additional
10hp worth of duration on top of what it adds in the tow mode. Then on the
extreme mode it adds another 20hp worth of pressure over the perf mode and
another 20 or so hp worth of duration over the perf mode. These amounts are
an approximate as many have made more hp than this on the dyno."
Brian
watson14
Dec 9, 2009 08:39 PM
dodgedude361
Feb 14, 2005 11:59 AM
sawboywv1
Oct 14, 2004 10:38 PM
