06 Boost Pressure Gear Based??
Old Jun 26, 2006 | 05:09 PM
boostjunkie1's Avatar
Smile 06 Boost Pressure Gear Based??
How much boost does the stock 06 trucks run. And if at all possible, someone that has already installed a gauge please list boost pressures in gears (Auto)!!! Thanks Again
Old Jun 26, 2006 | 05:19 PM
Bumpy Bump!
Hvytrkmech's Avatar
Mine will hit 30-32psi then the waste gate opens and starts dumping boost.
Old Jun 26, 2006 | 05:28 PM
Thanks!
Does it hit this amount in every gear, or just in top gear???
Old Jun 26, 2006 | 05:48 PM
Hvytrkmech's Avatar
From 2nd gear right up to 4th lock up, It hovers there, if I'm at WOT the whole time, It will peak at 32psi then drop to appx 29psi from the waste gate opening then shift and go right back up to 32psi and so on.
Old Jun 26, 2006 | 05:54 PM
nickleinonen's Avatar
boost is engine load depenent. more heat & pressure in the exhaust manifold, more boost...
Old Jun 26, 2006 | 05:58 PM
I'm curious if outside air temps effect the boost that the ECM calls for! I know that allot of the newer Factory Turbo'd Cars are ambient temperature dependant, but are our trucks????? 32psi then to 29psi = I love BOOST! Thanks
Old Jun 26, 2006 | 11:05 PM
wcjp's Avatar
My 06' 6spd see's the boost others in this thread are reporting. I'm running the dual Westach.
streetsmoker
Jul 6, 2006 07:04 PM
AlpineRAM
Mar 15, 2006 12:18 AM
DSjockey
Nov 5, 2005 01:48 PM
13
Nov 29, 2003 09:40 AM
