05 Ram Gauge Hook-up
Old Jun 12, 2011 | 07:37 PM
y1topbanana73's Avatar
I'm getting ready to install the EGT & Boost gauges, and as I understand the instructions they want you to tap into the factory wiring harness dimmer circuit. I'd like to NOT cut into the factory harness, and tap it via a connector somehow. Any ideas?
Old Jun 12, 2011 | 08:03 PM
rootkit's Avatar
via connector i dont know but i wouldnt worry to much about tapping on the dimmer switch. I did it and still good after beating the truck out in the dirt.
Old Jun 12, 2011 | 08:38 PM
rockcrawler304's Avatar
Mine are tapped into the dimmer wire and no issues. I say go for it. Just make sure to solder the wires for the best, most reliable connections. That's how mine are connected.
Old Jun 14, 2011 | 03:21 PM
MartinRdCustomz's Avatar
pull out ur headlight switch and it was the orange wire on mine i believe...maybe it had a brown stripe too. but thats where i connected mine...works great. dimmer works great too
caleb c.
14
Apr 10, 2005 06:17 PM
hotdram
15
Mar 9, 2005 07:18 PM
ts
Oct 28, 2003 10:36 PM
barracuda
30
Apr 22, 2003 05:55 PM
tomsauto
Nov 18, 2002 07:22 PM
