03 Ho egt question, useing predator and recon gauge.
Old Aug 23, 2007 | 10:29 PM
GrizzlyAdams's Avatar
Originally Posted by Mark03Ram
The prob is pre turbo, right around number 3 on top of the manifold. Just like it shows here under the dodge pyro section.
Pyro location http://www.quadzillapower.com/downlo...on_install.pdf
I did some more testing, 220 at Idle in N or P, 290-300 in D. Cruise at 60 is around 400-500 depending on hills. I ran it hard and hit 1k was prob 1/8th mile, was still going up but had to let out of it.
I have always said my truck seems to have a lack of power, its strong on ext stacker tune but just seems a little sluggish. I can spin tires but have to try and it just dont come close to my pops 05 on performance.
Could the EGT's be saying there is a issue, or is it possibly the gauge??
I am sure I could hit 1200 or so if I held it to the floor till over 100mph, well maybe I will have to try and see. I am just a bit afraid I am pushing higher egts then I am showing and could hurt it trying to figure it all out.
I hit 1400 today doing 60mph, I can slide my truck any direction I want..Tire spin comes very easy
Old Aug 24, 2007 | 07:17 AM
Mark03Ram's Avatar
you have a 06, 04.5 and up are different animals from what I have been told. Really I need to hear more from the 03-04 crew.
Old Aug 24, 2007 | 07:19 AM
MikeyB's Avatar
That's seems kind of low with a performance box. What's your EGTs in the stock configuration? Still running the stock lift pump?
With the SMARTY set to level 5 (90hp+timing) I'm at 1100 degrees WOT. Stock it's 1250 degrees.
MikeyB
Old Aug 24, 2007 | 11:30 AM
Mark03Ram's Avatar
Good question, might put it back to stock and see how that does. I do still have the stock lift pump, I have used the predator to monitor the rail pressure and it has never dropped off.
Guess my next step is to monitor the fuel pressure and figure out how to see if the gauge is accurate.
pipeman90
Mar 29, 2011 09:23 AM
Mark03Ram
Jul 13, 2007 07:42 AM
dieselminded
17
Dec 15, 2004 09:04 AM
diablo1
Oct 23, 2004 07:32 PM
Pa outlaw
Sep 6, 2004 09:04 PM
