Whistlling sound
Whistlling sound
I recently did an EGR cleaning on my totally stock '08. Now I feel that I'm hearing a whistling noise...goes along with the rpm increase as I gradually accelerate. It sounds much like a big truck's turbo, or like some of the played-with kid's trucks (especially Powerstrokes) that I hear running around town. I can't say for sure that I didn't have the sound before. Maybe I did and just wasn't tuned into it. I've gone over every hose/pipe/etc. joint that I had apart during the EGR cleaning and they're all tight. I had a leak at the rear of the EGR cooler once before. That made a squealing sound when the engine brake was working...this is nothing like that was. The truck runs great, although the fuel mileage sucks. I never did see this 2 mpg increase that everyone says happens at break in after 15k-50k miles. My best mileage was when the truck had 10k on it...
Any ideas on what I might be hearing? Or if it really means anything? There weren't inter-cooler cgrack issues on the '08's were there? If so, how would I get the dealer to check it?
You can check for boost leaks quite easily by using a 4" ( if I remember correctly) PVC cap and secure it into the rubber inlet hose on the front of the turbo with the factory hose clamp. I drilled and tapped a 1/4" NPT thread and stuck a quick connect and gauge in the cap. Hook up an air compressor, fill it to a reasonable pressure, 20 psi maybe, and watch for the pressure to bleed down. Assuming your engine isn't losing compression from bad rings or valves, you should see a steady pressure that doesn't drop off over time. If the pressure drops you probably have a leak in your piping, after cooler, or worn engine parts.
If you hear air leaking out of your exhaust don't panic, I just rethought the process. There's a good chance you will have some leakage as some of the intake valves will be open during the test, I seem to recall barring the engine over to the point of minimum loss and a spray bottle of soapy water to find the leaks did a nice job. Good luck!
samiam4
Dec 19, 2012 12:08 PM
MJR
Mar 16, 2003 08:26 PM
98rammer
Oct 16, 2002 12:24 PM
