trans troubles???
Old May 21, 2007 | 09:02 PM
SNOWHOUND's Avatar
trans troubles???
I have an 04.5 3500 lwb 4x4 ....seems crusing from 20 to aprox 35mph my truck shimmies (sp??) Its like the whole truck shakes but it seems hard to feel ..If I have a open pop bottle in the holder it shakes the crap out of it...it allmost feels like a torque converter...anybody else has this problem??? Thanks Kurt
Old May 21, 2007 | 09:07 PM
belgianmagic's Avatar
U-JOINTS MAN... our LWB are prone to it...get some "TIMKIN"S GREASABLE U-JOINTS AND THE STICKIEST GREASE YOU CAN FIND
Look at your Carrier bearing too see if it is centered or needs to be dropped 1/2 inch
EASIEST Way to check the joints...go hard around the neighborhood then get under and feel the caps for heat
Old May 21, 2007 | 09:35 PM
SNOWHOUND's Avatar
Carrier bearing was just replaced by dealer..I had a "HOWL" ...I just went to look and the carrier bearing is loose in the rubber...is that normal??? Thanks
clops79
Apr 30, 2010 10:05 PM
goodguyt488
Sep 17, 2007 07:33 AM
Teddy Bear
Aug 8, 2007 05:45 AM
one54ton
Aug 30, 2006 11:06 PM
