South Bend Clutch...G56 OKHD
Old Jan 12, 2013 | 09:04 PM
robby t's Avatar
Another g56 question....i'm about to replace my stock clutch for a solid flywheel organic single disc clutch.....425hp.900ft lb. just wondering if anybody is running this set up? or can give input on this south bend clutch...
Old Jan 12, 2013 | 09:27 PM
Danderson's Avatar
Thumbs up Sbc g-56 okhd
Yes. Mine's 100 miles old. Stock-like engagement/disengagement with minimal pedal pressure increase.
More positive shifts now.
The installer was an ex-pat Dodge tech who was very impressed with the product quality. Before this he had only reinstalled the stock dmf in Dodge's at the dealership.
Gonna baby it for 500 miles.
You'll like it.
Old Jan 13, 2013 | 10:57 AM
carl48's Avatar
we run a fleet of them set up this way. most are set at 425 hp 850 ftlbs. the one in my sig is 450hp 900 ftlbs. while you have the g56 out mix one gallon sae 50 synthetic syncromesh transmission fluid with one gallon 5w-30 synthettic syncromesh transmission fluid and use 7 quarts in the g56. we tow very heavy and have several hundred thousand miles on the southbend conofe. single disk.
Old Jan 13, 2013 | 11:04 AM
carl48's Avatar
i just copied this from another post. while you have the g56 out, replace the red rubber boot on the shifter.here you go: Moose Fast Boot II part # 0213-0427. $17.95. Available online or at your nearest ATV shop. Add a #48 hoseclamp to the bottom and you're done.
This is the one Mercedes should supply with the G-56.
Old Jan 13, 2013 | 01:25 PM
Danderson's Avatar
Carl,you're in NM which must experience some pretty cold mornings in the winter as we have lately. With your fluid combo,how's the cold shifting first thing in the morning? My G-56 has always been sticky shifting from reverse to 2nd initially in the morning and the whole thing's stiff for awhile. I'm running Pennsoil Synchromesh.
Thanks
Old Jan 13, 2013 | 04:12 PM
carl48's Avatar
in ruidoso this morning when i got up it was 2* below zero. it shifted ok. a little stiff for about a 1,000 feet. the gorilla juice or the sae 50 alone does not shift for 20 miles. in the cold. at 20* below zero, this formula worked good. not to much harder than the penzoil.
Old Jan 13, 2013 | 05:40 PM
Danderson's Avatar
Thanks. GJ lasted 45 miles in mine awhile back. It was donated to O'Reilly's recycle tank. Not tax deductable unfortunately.
Old Jan 13, 2013 | 07:54 PM
leonesm's Avatar
Can't speak about this exact setup but have 240k on an OFE in my NV5600. Nothing but the highest praise for the product and the customer service provided by South Bend. I've never experienced any slipping with my clutch and I've been continuously modifying the truck since the installation.
Old Jan 13, 2013 | 11:47 PM
robby t's Avatar
hey carl....what brand sae 50 synthetic syncromesh oil are you using? i've been looking for mobil delvac 50......hard to find
Old Jan 13, 2013 | 11:52 PM
robby t's Avatar
Old Jan 14, 2013 | 09:07 AM
carl48's Avatar
i stock the dello for my big rigs, you can get it from the chevron distributor. you can get the delvac from ww granger, they will even ship if you do not have one near you, royal purple is available through napa, amsoil available everywhere any distributor will Carry a equivalent as that is what is used in the roadranger transmission.
Old Jan 14, 2013 | 09:35 AM
Danderson's Avatar
Somebody else posted that Zoro Tools carries it also. I got on their website and couldn't find it. You might Google that in and call them. They were considerably cheaper than Grainger where I obtained mine.
Old Jan 14, 2013 | 02:46 PM
robby t's Avatar
thanks guys for all the great info...I did find mobil delvac 50 at grainger ..now just ordered the moose fast boot II cv boot...then i can start teardown for the south bend g56 okhd....
Old Apr 30, 2015 | 11:38 AM
bishgeo's Avatar
Clutch noise
I am running the con ofe sb in my 05 g56 and 7 qt a of royal purple synchromesh. Got 86000 on clutch daily driving and pulling 16k fiver. Starting to get clicking or cracking noise when I push clutch in. Any body else have this or any ideas.
Old Apr 30, 2015 | 12:47 PM
Jona Gold's Avatar
That's 71K miles more than I got out of mine...
