Smarty JR question
Smarty JR question
Truck is back in the shop once again for third or forth turbo an four sensors all emission related. I'm going to order the Smarty jr. what i need to know is what all does it do thru the programmer only? Does it do the deletes thru the programmer or do i have to buy block off plates that I've seen in some pics. posted. I hope this will end all the problems I'm having with the truck, it's costing to much to operate from the 2 1/2 years from new. Help would be greatly appreciated.
Take a look at this thread. It should clear a bunch of stuff up for you.
Everything that is described in the thread can be done with the Jr.
https://www.dieseltruckresource.com/...t-t273345.html
I assume you mean the blocker plug that is in the crossover tube.
No its not nessecary unless you really want to remove it. You can leave the crossover tube in place.
If you do remove the crossover tube, then you might as well remove the cooler too, and then no, no need for the plug in that case either.
If you remove the cooler, you must purchase the EGR Cooler delete.
That will work , i'm going to order the jr. tomorrow i dont know when my truck will be ready it went in Monday. But one thing for sure it will be another couple of thousand again. Thanks for replying back. I'll let you know whats up.
All righty then. They did give me a call today on my truck status .Replaced turbo (i marked my old one) told them i wanted my pull off back. Replaced numerous sensors, not sure how many yet. Replaced particulate filter no sure how much that is an doing a complete de sooting. Might have to sell the dog an pawn the wife.
If your paying, Id tell them to replace the turbo and thats it.
Delete the rest of the stuff.
Got the Smarty JR. in today an Blake said down load the ME on to the programmer? What is this for? I'm still waiting on the egr cooler block off plates and also the exhaust system.A question that i have is do i need to wait to put all this on BEFORE i do the programmer???
The "ME" program is the Middle Eastern Market tune. They have no emisions compliance so that tune is designed to override the Bluetec system.
Look here to download the program to update the Smarty and for the ME program itself.
http://www.madselectronics.com/DownloadJ67ME.html
You will want to have all of the deletes in place before you program it.
"California Style"
