Small lift big problem
Old Oct 29, 2007 | 09:38 AM
pigman300's Avatar
I have a 2007 Mega Cab 2500 with the new 6.7 diesel. I installed a 4" superlift kit with Bilstien shocks all around to accept the 315/70R17 MTZ's from Mickey Thomson. Rough sections of highway will cause the truck to shake violently. In some cases the truck will continue to shake after the rough road has ended. I am using 45psi in my tires and have put them up to the maximum recommended as well, it doesn't seem to make a difference. Has anyone experianced this? Have any suggestions on what to try?
Old Oct 29, 2007 | 10:07 AM
Spooler's Avatar
Do a search for Death Wobble. Lots of info on it.......
coolbreeze's Avatar
Bummer. I suggest staying off those rough roads though. Sounds like a real old 4X4 before steering stabilizers. Good luck.
Old Oct 29, 2007 | 10:26 AM
BlackSunShyne's Avatar
Have you aligned it since the lift?
Old Oct 29, 2007 | 01:52 PM
john.overton's Avatar
Just curious, did the kit come with a drop pitman arm. A lift without it would change the geomotry of the steering. Also check your steering stabilizer, looks like a shock but sideways.
Old Oct 29, 2007 | 02:26 PM
ptgarcia's Avatar
You got the death wobble. Do a search and start reading.
Old Oct 29, 2007 | 05:40 PM
pigman300's Avatar
The lift did come with a drop pitman arm and i can't see the steering stablizer being worn out because there is only 12000km's on it. I've heard of death wobble but I always thought it was caused by worn out front end parts. Thanks for the info.
Old Oct 29, 2007 | 05:59 PM
n0ne's Avatar
I have the same problem pigman. My truck has the same lift. And it shakes side to side when on the interstate.. Even when it isnt that rough. but the steering wheel doesnt move.. just the rest of the truck shakes..
Old Oct 29, 2007 | 06:04 PM
ptgarcia's Avatar
Not only worn, but inadequate from the start.
If your kit has a track bar drop bracket make sure you weld it no matter what the instructions say. A couple 1/2" beads will do.
If your kit reuses the factory track bar I'd replace it. I recommend this one.
When your steering stabilizer goes replace it with something better. I think this one is the best value.
Finally, be sure your truck is aligned, and what has helped many is setting castor high, like around 4*.
Good luck!
Mexstan
Dec 2, 2012 06:28 PM
CruisingRam
Jan 19, 2012 04:45 PM
bigdrdge02
Off Road / 4x4
13
Nov 12, 2010 06:01 AM
Artsi_L
56
May 21, 2007 09:31 PM
Mule Skinner
Sep 9, 2003 10:26 PM
