Runaway Truck ...newbie Needs Help
Old Aug 29, 2010 | 09:08 AM
saltydog2's Avatar
Originally Posted by mega-engr
If the torque converter were locked up then it would probably make the motor die when you come to a stop and hold with the brakes. Like not pushing in the clutch... Something else could be wrong with the torque converter though and it is acting "sticky" and your computer on the truck is stepping it up to keep it from dying.
What do the RPM's do when you shift from drive to nuetral? Do they shoot up a bit and then down to 750? As in, the computer/motor is stepping it up due to some converter load and when you shift out of gear, you get a momentary bump in RPM and then down to normal when in nuetral.
thanks for your reply. yes thats exactly what it does.
i was wondering if the solenoid valve that controls the lockup on the torque converter could be defective, sticking, clogged, etc causing a small amount of hydraulic pressure to partially engage the torque converter clutch but not all the way.therefore making the vehicle want to creep. does this sound logical to anybody and has anyone ever experienced this???? thanks
Old Aug 30, 2010 | 03:09 PM
ACE4U's Avatar
I have the same problem every so often it just want's to take off. Or have a very slow start on drive then it kicks inn back to normal speed. I haven't had any tranny work done on mine and it has 33000 miles on it. I did the code search on the dash. And the board say's done and I get no code's. Yeap no codes ? ? ? ?
Old Sep 1, 2010 | 05:10 PM
saltydog2's Avatar
UPDATE ON TRUCK. TOOK TRUCK TODAY TO A LONGTIMEV ESTABLISHED REPUTABLE TRANSMISSION SHOP. PUT TRUCK ON SCANNER...COULD NOT FIND ANYTHING WRONG. TRANS SHOP SAID HAD NEVER RAN ACROSS ANYTHING LIKE THIS. WAS GOING TO CHECK INTO IT FURTHER AND GET BACK TO ME. UPON LEAVING SHOP SUDDENLY THE TRUCK MADE A BANGING NOISE AND WAS SUDDENLY OPERATING PROPERLY. BEFORE I GOT HOME THE PROBLEM OCURRED AGAIN BUT BY THE TIME I GOT HOME IT WAS OK AGAIN. I GIVE UP............YOU TELL ME!!!!!!!!!!!!!!!!!!!!
Old Sep 6, 2010 | 09:53 AM
saltydog2's Avatar
reallyREALLY GETTING FRUSTRATED NOW. WAS HOPING SOMEONE WOULD COME UP WITH A SOLUTION. AN EXPLANATION. ANYTHING!! i know theres an answer out there somewhere,
redrum323
Apr 25, 2007 01:39 PM
michaelsmalley
Oct 15, 2006 02:13 PM
cowboy717
15
Aug 22, 2006 05:41 PM
Kevco
Jan 20, 2006 10:17 PM
wmwise
Jul 13, 2005 08:10 AM
