Rear Spacers on 08 Rear Springs
Old Oct 27, 2008 | 08:48 PM
Polaraco's Avatar
Old Mopar Aficionado Extraordinaire
Has anyone removed the spacers under the rear axle to lower the rear? I want to know if it changes the Drive shaft angle any.
Thanks
Old Oct 27, 2008 | 08:50 PM
dj88382000's Avatar
yes it will change the driveline angle...you will get a major driveline vibration
Old Oct 27, 2008 | 08:53 PM
Polaraco's Avatar
I figured. . .
I hear yes and no on the vibration. Not cool on changing U joints every 10,000 miles.
I figured I had to shim, but finding shims that big is going to be a problem
Thanks
Old Oct 28, 2008 | 08:04 PM
gandrews's Avatar
I lowered the rear of the 07.5 around 8,000 miles ago - about 6k of which was towing a 12,000 lb 5th wheel.
I have not noticed any vibration.
I used this link for guidance http://klenger.net/dodge/lowering-rear-end/slide01.html
Good luck,
George
Old Oct 28, 2008 | 08:12 PM
Kenny D's Avatar
that makes no sence if you dont take out the wege shape shim and only remove the flat plates. I think they are 3/8 thick no vibration should be felt. if doing that cuased vibrations when you loaded it and it squated a litle it would vibrate from that change in stance. right ???
Old Oct 28, 2008 | 09:34 PM
Polaraco's Avatar
Good luck,
George
Thanks George Perfect. But he didn't talk about if he had a vibration. . .
I guess I can give it a try. .It's reversible
redramnc
Mar 23, 2007 02:06 PM
cowboy717
Dec 31, 2006 01:38 AM
nitis
13
Oct 21, 2006 10:07 AM
Derek Timm
17
Feb 10, 2006 08:11 PM
Holiday
Jun 21, 2005 10:34 AM
