Rear end oil weight
Old Mar 18, 2009 | 04:53 PM
Dauntless's Avatar
Rear end oil weight
Can someone tell me what grade oil I should use in the rear end. Amsoil offers 75W-90 and 75W-110. Which should I use in my new 09 3500 dodge.
Dauntless
Old Mar 18, 2009 | 05:36 PM
SundayMoney's Avatar
AAM recommends 75w-90.
Higher viscosity gear oil isn't always better.
Old Mar 18, 2009 | 09:00 PM
adamsmarshall's Avatar
where are you from? I've seen some say to run the 75-110 in cold climates while others use 75-90 no matter the condition, I personally run Royal Purple Max Gear 75-90 and love it though.
Old Mar 19, 2009 | 03:23 AM
Hounddog's Avatar
75w90 is what the specs call for.
Old Mar 19, 2009 | 07:04 AM
Jim W's Avatar
I checked here and several other forums before I changed mine at 15K. Most of the hotshoters that use the trucks daily for towing are using 75W-110. I do not pull every day, but do pull a 5er for camping during the summer camping season. So I put in Amsoil 75W-90 with a Mag-Hytec Diff cover, used 8 Quarts.
Just my $0.02
Old Mar 19, 2009 | 11:28 PM
Lil Dog's Avatar
OEM fluids are synthetic in the diffs already. Why the quick change?
Old Mar 20, 2009 | 07:09 AM
Jim W's Avatar
Per Dodge requirements ( in your owners manual) the front and rear diff fluid must be changed at 15K. I tow a 5er during the camping season thus I follow the manufactures recommendations. I also installed a Mag-Hytec diff cover on the rear axle for more cooling and more fluid capacity.
Old Mar 20, 2009 | 11:27 AM
Lil Dog's Avatar
Fair enough...
John Marshe
Aug 14, 2020 09:00 PM
Purplezr2
Jul 25, 2011 04:31 PM
ibcumns
Apr 19, 2010 01:13 PM
doorguy
Jun 8, 2007 06:19 AM
Aug 28, 2003 12:56 PM
