Ram 4500 automatic
Old Jan 22, 2008 | 11:56 PM
Mach 1 delivery's Avatar
Ram 4500 automatic
New ram 4500 automatic 6spd aisin 4.44 axles .
Trany seems to shift to soon from 3rd and on. Causing the motor to strain its way up to higher rpm only to shift again. Tow/haul and od/off don't seem to change the up shift timing only the down shift timing.
Truck only has 1000 miles.
Has anybody else experienced this trany yet.
Old Jan 23, 2008 | 06:52 AM
bigblock2stroke's Avatar
I'd rather have the engine utilize its high torque capacity to try and accelerate vs. having the engine spin faster to use hp to accelerate.
remember you also have less power available with the CC models vs. those that come with a box on the bed (less power than the 04.5 - 07 5.9L models too).
Old Jan 23, 2008 | 08:03 AM
jkitterman's Avatar
Are you loading the truck or are you talking about it empty?
Old Jan 23, 2008 | 05:36 PM
Cummins610's Avatar
Yea the Aisin likes to shift 3rd,4th,5th and lower RPM, Mine got 488's so I don't know about yours.....its a different machine with a load on,Mine holds a gear longer
Old Jan 23, 2008 | 10:51 PM
I haul a 30' gooseneck flat deck 6800lbs. Plus 15000lbs payload.
Im just looking to see if this is normal, my 05 3500 was good at screaming thru the gears haha. Should I be worrying?
v8440
Apr 10, 2006 04:05 PM
okcummins
Jan 19, 2004 11:39 PM
RamThatStroker
May 29, 2003 07:38 PM
doomgaze
Jan 6, 2003 02:12 AM
