odd ball question
Old Jan 17, 2008 | 11:10 AM
hammerhead's Avatar
wacky problem with truck????
I have a 2003 cummins truck that I have put an edge juice w/ attitude on. I ran it with no problems for about a year. During the summer I noticed that the load % reading on the attitude would go up to about 10-14% while the truck was idling sometimes. I believe the truck idles a little faster than it used to as well. this would come and go and I didn't worry too much about it at the time. Well a month or so back it started to do this all the time. I took it to the dealership and they tested the lift pump and what not and said everything was good. I sent the juice back to edge once for a re-flash once and the second time they gave me a new one.
Now, knowing all that ,does anyone have any ideas about what is making the truck think it is under a load even while it is idling? when you are driving down the road and let off the gas pedal the truck will go to 0% load until you push in the clutch. Then the load percent goes up to the 10-14% range again. I am stumped and need some help.
Old Jan 17, 2008 | 11:17 AM
rustyshakelford's Avatar
does it effect the operation of the truck or are you just concerned about the read out? if its not acting up, i wouldnt worry about it.
brett
Old Jan 17, 2008 | 11:29 AM
hammerhead's Avatar
The truck seems to run fine. I'm mainly concerned that this may be a symptom of a bigger problem. Either way I know that something is up since it has done this with 3 different edge juice modules.
Old Jan 17, 2008 | 03:55 PM
Double-D's Avatar
This is normal my truck does it with banks and my dads 01 has an edge on it and it is showing the same as yours. On idle the truck is under a little load.
Old Jan 17, 2008 | 08:49 PM
hammerhead's Avatar
Thanks Double D. That puts my mind at ease!
grishfish
113
Mar 3, 2013 10:53 PM
Wulzcat
Dec 19, 2009 05:15 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
welndmn
Jan 31, 2007 07:59 PM
