mp-8 or edge juice with monitor
i stuck between these 2 chips mp-8 and edge i was told to stack them both but my hot rod days are over im tryin to get mpg's so can yall help me out
For a truck that you are going to use to tow the Edge Juice wam is going to be a better option for you. It will give you the gauges as well as the adjustability on the fly. The juice wam also has some safeties built into it to help with the EGTs. Great bang for the buck....
I have the MP-8, Juice and the power pup. The MP-8 is good for milage and power. The edge is great cause of the gauges. The pup just makes alot of noise.....literally makes the engine LOUD.....
The MP-8 also runs cooler on my truck then the edge. But the edge makes less soot so less regens. Edge has a bit more bottom end. MP-8 Pulls smooth all around but this "feels" slower but runs the same 0-60
My opinion. I like the mp-8 better, much cheaper and if you prefer real gauges its win win.
My juice, exellent, gauges to monitor your temps, while driving, built in adjustable alarms, turbo cool down, mpg went up, no experience with the mp-8, keep mine no more than 2k rpm and still pass the gassers, regen happens u just have to let it run thru the cycle, and 90% of the time when I am ready to shut the beast down the regen is already done.
I just got my edge jiuce with att. and so far am happy with it. My mpg are a little higher and the power is great. On a side note it's amazing how often my truck goes into regen, no wonder we get such bad mpg with these 6.7 compared to the 5.9's.
nitis
Feb 26, 2007 07:38 PM
razor6
22
Jan 20, 2006 03:43 PM
Hondo
Mar 3, 2005 06:40 PM
