Launch Shudder question
Old Jun 23, 2009 | 09:43 PM
DB07's Avatar
Hey guys, question about this shudder when driving away from a red light. Truck is a '07 MegaCab, 3500 DRW, 2wd, 2000 miles. This could get long, I'll try my best! This shudder seems to get worse when hauling for longer periods. Trailers are 24' enclosed, with 3000 lb race car, and 27 foot enclosed 3200 lb empty weight, 4 fourwheelers and gear. Both tongue pulls. Dealer says no TSB's for my truck on this, and sends me on my way. I've read that some guys were adding spacers to the carrier bearing to change the driveshaft angle and this is a fix. I spend the morning adding spacers, and it seemed to get worse with more spacing. So I spend the afternoon making a shorter bracket that the carrier bearing bolts to and started raising the carrier bearing. Seemed to help abit, but the shutter is still there on my test runs with trailer. Any suggestions on this, or is this something that just happens to some trucks, and I gotta deal with it?
Dave
Old Jun 24, 2009 | 07:23 AM
Chubby's Avatar
All my dually dodges have had a little shudder, But It isnt that bad. I have been in fords and chevys with long driveshafts that have done that too.
Old Jun 24, 2009 | 05:17 PM
J BODY's Avatar
I've fought this numerous times with customer trucks (usually under warranty). Each time air bags have been the answer.
Old Jun 25, 2009 | 10:56 AM
LeonT's Avatar
Mine has had some shudder on launch since I've had it. I can't imagine needing air bags on a 1 ton dually (at least for what I do), but maybe it's worth a shot. I never thought of that.
Old Jun 25, 2009 | 10:59 AM
LeonT's Avatar
Mine makes a lot of shudder noise at certain low rpm's when just creeping along too. I can feel the vibration. The dealer always says it's "normal" with these trucks.
Old Jun 25, 2009 | 02:51 PM
J BODY's Avatar
It is.....until you put air bags on. I fought one for a couple days adjusting the pinion angle, shimming the hanger bearing. If I made it work good pulling, it would introduce a vibration empty while driving. FINALLY convinced the guy to spring for some bags. Unfortunately it was at his cost, but it works and he's happy now.
Old Jun 25, 2009 | 05:42 PM
aceheater's Avatar
I had the same issue with my truck since I drove it off the lot. I just got used to it and it got better over time. I now 33,000 on the truck and it has gone away totally. just my .02
Old Jun 25, 2009 | 06:45 PM
Lil Dog's Avatar
This is with an auto?? The axle tramp/wrap idea may be the problem. Is it better on or off the overloads?
Old Jun 26, 2009 | 11:26 AM
ropnjessi's Avatar
There was a TSB on my 03 on launch shudder, and that is what we did, added 1/4" steel plate to the carrier bearing and that solved the problem, but in my case once I was loaded the shudder would go away, how much did you add?
Dave
Old Jun 26, 2009 | 11:47 AM
Robert373's Avatar
https://www.dieseltruckresource.com/...e-t202733.html
One piece driveshaft seems to fix the problem. I would do this long before I put airbags on.
WVU Dodge
Nov 11, 2006 05:39 PM
Harbaw
Jan 26, 2006 09:45 PM
brandon507
Nov 17, 2005 04:22 PM
cquestad
Aug 9, 2005 04:10 PM
Ponderosa
Feb 25, 2004 07:15 AM
