Injectors life on a 3rd
Old Dec 14, 2014 | 12:57 AM
Grit Dog's Avatar
Originally Posted by diesel yukon
I just bought a 2005 ram 3500 just wondering how much that Eco tune has improved your fuel mileage?
Sorry I abbreviated "Eco". I meant a towing tune or something not more than 30-50hp ish.
I have a Bullydog triple on my 07. Honestly I don't think any of the tunes do much for the mileage. Certainly don't make it worse, but I seem to get about the same regardless of power level.
A different tuner may help with mileage thou.
Old Jul 4, 2015 | 12:18 AM
diesel yukon's Avatar
Originally Posted by John_P
diesel yukon:
I will agree with your friend that the 5.9 CR Injectors are troublesome. On my now sold 2006 Dodge CTD CR, I had to replace the first set at about 94,000 miles. I replaced them with brand new Bosch Injectors and those were starting to give me trouble at about 198,000 miles!
I don't really undertsand why the 6.7 injectors seem to last longer. If you tear down a 5.9 CR Injector and a 6.7 CR Injector "side-by-side" they are very similar.
As Dr. Dizzle pointed out they are ALL EXPENSIVE! But as he said, which I agree with, if you go to buy any of them BUY NEW ONES!
IMHO,....the 5.9 Cummins (Bosch) CR Injectors are JUNK! I think they should last much longer than 95,000-100,000 miles and while some sets may, many DO NOT!
John_P
What were the tell tail signs of the injectors going out?
Old Jul 4, 2015 | 09:03 AM
John_P's Avatar
Diesel Yukon:
On my 2006, it kept getting harder to start. By that, I mean the crank time got longer and longer. Also, I was getting some blue smoke on start-up which had never happened before and my mileage was way down from what it normally was.
As soon as the new injectors went in, all those symptoms went away and
the truck ran great again. BTW,....all of my injectors had low pressures and two had very worn nozzles.
Old Jul 5, 2015 | 12:07 AM
Diesel Yukon:
I bought a 2005 with 111,000 miles it gets 22MPG now has 129,000 on it. Guess I'am just use to my 12 valve & 24 valve VP44 where I just bumped the key and it was purring. I should of just moved up to the 3rd gen 6.7 & passed on the 5.9?
Old Jul 16, 2015 | 12:42 PM
Gerry1238's Avatar
Have a 2003 Ram 3500 with 5.9 Original injectors replaced at 390K hope to get same out of replacement.
Old Jul 27, 2015 | 08:03 PM
Were you running any fuel conditioner and how often were you changing fuel filters?
Old Jul 27, 2015 | 10:01 PM
jumper's Avatar
After losing a set of injectors in Yellowstone Park towing the fiver I left three large at Wyoming Diesel in Cody, WY in exchange for a new set of injectors. I'd been inconsistent about fuel conditioner, especially on that 3K mile trip loaded in the mountains. They said always to run a fuel conditioner to replace the sulfur that used to lubricate injectors. I won't fill up without it now and with about 100K on the new ones, so far, so good. I also run the Baldwin filter in the stock can.
The truck smoked a lot and his STAR tool confirmed most of the injectors were bad. I highly recommend those guys. They worked me in at lunchtime and had me out that afternoon.
Old Jul 27, 2015 | 10:21 PM
Gerry1238's Avatar
Injector Life on a 3rd
I did not use an additive but replace the filter between 10-15K. Several other transporters claim they added a quart of transmission fluid to 35 gal tank of fuel to lubricate the injectors.
Old Jul 27, 2015 | 10:54 PM
jumper's Avatar
Trans fluid at that ratio is a lot more expensive than purpose-built fuel additives. I use Standyne or Red Line.
KRB
May 20, 2007 06:20 PM
1qckdodge
Mar 5, 2007 09:53 AM
dieselbeef
Jun 12, 2006 08:12 AM
BIGOKIE
Jul 21, 2004 05:53 PM
