I uhhh, need a quote?
Old Jun 10, 2008 | 12:51 AM
ktmrdr85's Avatar
Obviously, Dodge offers their 100,000 mile warranty (or whatever it is, maybe someone can specify) on their diesel trucks.
The warranty probably includes the motor, the tranny, and the axles.
Since I would get a 6-speed and a south bend clutch among other possible things, I wouldnt worry about the tranny. The axles are probably strong enough to handle a tuner too, so thats not a worry.
Heres the worry: if I got an '08, put an Edge tuner on it, and for some reason blew the motor sky high (which isnt likely, but I want the scenario played out right), then as soon as I put the tuner on, the truck's warranty would be the worth of a bag of dog crap.
So, if something happened, what would it cost me for a new motor? Installed, ready to roll?
By the way, how likely is it that something like that should happen?
Old Jun 10, 2008 | 04:08 AM
Hounddog's Avatar
A LOT! Lots of differant pricing and sceniros. $7k to 15k I would think.Lots of depends.
Old Jun 10, 2008 | 06:24 AM
CamperAndy's Avatar
The fact you asked the question "How likely is it that something like that should happen?" says you are aware of what you are doing and would not likely be out there beating on it all day long. Thus you are unlikely to blow it sky high as you say. That said the fact you are modding the truck means you are expecting to run things to the limit sometimes and so you will likely fail something, I just doubt you will blow the motor up in the process.
You play you pay.
Old Jun 10, 2008 | 06:43 AM
Totallyrad's Avatar
I think the last number I heard anyone mention for a "new" engine was 15k installed.
Old Jun 10, 2008 | 10:48 AM
ktmrdr85's Avatar
Okay, just so I understand the motor is it true that you can just re-sleeve it and drop in new pistons?
I want to know because in the unlikely event that something happens that I could fix it myself-as long as there is nothing wrong with the block.
Old Jun 10, 2008 | 11:09 AM
Hounddog's Avatar
Kinda that way with most motors,sleeving one that is.
Old Jun 10, 2008 | 12:24 PM
BroncoHound's Avatar
Dude, it's a CUMMINS. If you drop an Edge Juice on the truck you aren't going to blow up the motor unless you run it over redline for 1000's of miles. These things are meant to last. Normal maintenance and run the hell out of her. She will love you for it.
Old Jun 10, 2008 | 03:22 PM
rich's Avatar
you cant resleave these their is no sleave you bore it out and sleave it. 5.9 block installed is around 13k and up. you wont blow the motor up usaully the pistons score or get holes in them.
Old Jun 10, 2008 | 05:30 PM
Spooler's Avatar
Just let it ride like it is. With the 6.7 I wouldn't even go there due to the trucks being more complicated and flat out expensive. Leave it alone.
Old Jun 10, 2008 | 07:23 PM
I think he will probably need the edge to clear soft codes thrown once some parts fall off his truck. if he needs the edge for the same reason i am putting one on mine, anyway.
Old Jun 10, 2008 | 07:31 PM
Hounddog's Avatar
Buy a Harley.One of Harley forums is so much like this one with more humor.Heck they even have Death Wobble and other issues that are similar..Think ones in my future.
Old Jun 12, 2008 | 12:58 PM
skalleknull's Avatar
Why spend 40,000 Dollars and worry about blowing up the motor. If you are the one that cause the engine to blow up, why would you want somebody else to pay for it. You should find a used 12v or something like that. if you can not afford to play you should find a new hobby.
Grand Geek
Sep 2, 2010 01:12 AM
jncornett
May 12, 2007 11:41 PM
