HELP engine knock and shakes really bad
Old Nov 17, 2008 | 07:09 AM
CTD03's Avatar
over the weekend i just finished up with valves and put every thing back together and when i started truck i had a bad knock going on and was getting ready to shut it down and then i had a bad shake so whats going on
are the valves out of adjustment or do i have the injectors harness hooked up wrong.
i am going back at it Tuesday around 6pm so i hope some one can help me out thanks
Old Nov 17, 2008 | 07:14 AM
Dodgezilla's Avatar
You are in the 6.7 section. You should move this to the correct forum..
I think it sounds like an injector issue. Make sure everything is buttoned up nice and tight.
Old Nov 17, 2008 | 07:51 AM
CTD03's Avatar
THANKS dang i didn't pay attention hope they move it for me thanks
yes i am going to take my tst off the truck any ways
please remove from this section i posted it up in 03 section thank you very much
Old Nov 17, 2008 | 10:09 AM
coolbreeze's Avatar
You may be in the right place. Sounds like you need a new truck. Good luck.
Old Nov 17, 2008 | 02:28 PM
CTD03's Avatar
Admins Can you please move this to 03-07 5.9 so more people can look over this thanks
Old Nov 17, 2008 | 07:32 PM
manganos's Avatar
Assuming you put everything back together ok it sounds as if you have air in the injectors/lines. Try bleeding the injectors.
Zee
Mar 23, 2010 09:54 PM
HappyGA
15
Oct 16, 2006 08:21 AM
Hoss
30
Oct 3, 2006 02:57 PM
