Help!!!!
Old Oct 2, 2013 | 04:26 PM
Adtopping's Avatar
Help!!!!
I just bought a 2008 2500 with a 6.7 in it. Someone had deleted the dpf but kept tge programmer. So I have purchased a race ME tuner. Went to use it but my truck is puffing black nasty smoke every little bit and today started making a noise like the turbo is spooling up. It also idles up for no reason. Any help would be great thanks.
Old Oct 2, 2013 | 09:08 PM
2006BLKMegacab's Avatar
when it started to make the turbo spooling noise was it at an idle? the exhaust brake will come on to help warm the truck up and produces a noticeable exhaust noise.
also the truck will idle up to 1000 rpm when the water temp is low after the truck has been idling for 2 minutes.
when does it smoke? if its under acceleration or increasing load it may just be a normal amount of smoke????
Old Oct 3, 2013 | 09:27 AM
Adtopping's Avatar
yeah it makes the noise at idle and gets worse as it runs. it is a lot if smoke. it has me stumped. it almost acts like the butterfly in the intake horn is closing and causing a vaccume. loading it with fule
Old Oct 6, 2013 | 09:04 AM
if you are deleted and plan on keeping it that way, is it worth the 60 bucks to buy a throttle valve delete and remove I as a possible cause, you can buy the cast not so shiny TV delete from Glacier diesel a lot cheaper than the machined ones to make it an affordable test. might be worth a try in my mind
Old Oct 6, 2013 | 04:59 PM
Adtopping's Avatar
Man thanks for the help. I am gonna do some wrenching on mty egr and see what happens.
kcredneck
Jul 25, 2007 10:11 PM
ollie32
Jun 6, 2007 09:21 AM
2500TurboDodge
Jul 31, 2006 04:21 PM
bkay
Nov 6, 2003 10:39 PM
