H & S DPF Delete
With out the pressure box and not letting my edge clear the codes, the overhead will say catalyst full and get a code for dpf pressure low. Cant remember the code # will look and post later.
I have a buddy running one and he still gets the odd code pop up. He just has the Edge juice with Attitude on it and it is set to clear codes on startup. That way you never have to worry about it. He is saying he picked up almost 5mpg and his egts are substantially lower.
BD Power does not sell or install or condone the use of the delete pipes
I had one on the 08 I used to own. Between that and simply unplugging the EGR my mileage went up 3-4 points. Well worth the investment. I had a constant CEL from the EGR being unplugged and I got codes on occasion from the DPF delete but I never really noticed it because the CEL was always on anyways. No big deal.......
What would happen if you get a second EGR and plug the connector into it? Will it still throw codes? A friend drives a new draggin wagon with the 6.7. At 6000 miles the EGR needs to e replaced. Thanks Keith
king cotton
Nov 24, 2010 10:33 PM
MegaCabinPA
20
Jan 30, 2010 11:23 PM
highrpms
Feb 25, 2009 05:38 PM
Red3quarter
Nov 8, 2008 04:11 PM
