Fuel Filter change
Old Sep 10, 2007 | 04:06 PM
GMScott's Avatar
Fuel Filter change
OK, so for the 5th fuel filter change I thought I would try something different rather than taking the wheel & fender well off to change the filter. After opening the drain tube (ha ha) and then loosening the filter about 2 turns to actually get the filter to drain, I went in the engine compartment from the top. There is a big junction box with cables going in & out on the driver's side. It has 2 squeeze clips, 1 on the bottom & 1 on the top. I removed the box from it's bracket and saw a little "daylight" that might be enough to allow me to get at the filter, take it off and then fish it up thru the opening in the bracket. Yup, it worked and I even managed to get the new filter on from above, however I looked like I was in a knife fight without a knife as my right arm got tore up from all the junk I had to reach around to get at it.
This way was definitely less time consuming and less crap to R&R to complete the job but a bit more bloodier!!
Old Sep 10, 2007 | 08:54 PM
CaptSanner295's Avatar
Good news!
Old Sep 11, 2007 | 07:33 AM
tr2162's Avatar
good idea.
The Dodge service tech said they are replacing the fuel filter from below. Is this possible only when lifting the truck in the service bay? The tech acted like it was no problem. Without the lift it looks too far up. Not sure this technique can be done from home.
Old Sep 11, 2007 | 10:21 AM
Glasshog's Avatar
GMScott, how many miles on your truck?
Old Sep 11, 2007 | 10:32 AM
GMScott's Avatar
Just flipped 57k miles.
Old Sep 11, 2007 | 04:00 PM
Glasshog's Avatar
Wow, lotta miles for that new of a truck. Must o a lot of pulling. Any problems with the truck so far? Excuse me if you already made trouble posts. Just point me towards them
Old Sep 12, 2007 | 08:32 AM
GMScott's Avatar
Only problems have been with the EGR system.
X - that's my crossed fingers!!
Old Sep 12, 2007 | 09:59 AM
Hired Gun's Avatar
Had mine done yesterday when they put the new turbo on. The tech pulled the fender liner off and bam had it changed in a few seconds. New turbo is doing fine. No cel light for the first time in many miles.
Old Sep 15, 2007 | 12:56 AM
jerry61's Avatar
I have almost 66,000 miles on my 07 and have changed the fuel
filter everytime i've changed the oil,,, about every 5-7K miles and
have always changed the fuel filter from below. I run the front
end up on ramps, crawl under and have it changed with very little
hassle in about ten minutes and most of that time is waiting for the
fuel to drain out of the old filter. I wouldn't even think of removing the
tire and inner fender.
To me it is more of a hassle to change the oil filter,, also from below.
jerry
jmccart
13
May 27, 2009 09:45 PM
vegashd
Jul 15, 2007 12:24 PM
Lunyfringe
Jan 10, 2005 05:40 PM
doitl8r
Jun 4, 2004 11:14 AM
XTOAK
17
Aug 23, 2003 09:07 AM
