To flash or not to flash
Old Oct 22, 2008 | 10:05 AM
Dodgezilla's Avatar
Since mine is an 08 it will not have the same flashes as your 07 will. I don't even know which one I have. I have to PM RatlRatl w/ my VIN# and have him pull up my info... Mine is either the newest or next to the newest because it "Should have" had the latest one when I bought it in early March...
Old Oct 22, 2008 | 10:46 AM
coolbreeze's Avatar
Originally Posted by pateric
I just got back from the dealer after getting the Turbo Cleaned and the ECM updated, when I looked under the hood for the tag with the latest Flash information the only one I had was for the flash that was done in March 08 (I believe this was the G30 recall) . Thinking maybe they just forgot to put the sticker under the hood, but was wondering:
1) If there is a way to verify what Flash my ECM is on via a scan tool or some trick?
2) If there is any other location I should be looking for the sticker?
I am just kinda a Nut (my wife calls this obsessive) about this stuff and really like to be informed about the work done on the truck and wanted to make sure I looked everywhere before calling the dealer to ask what Flash they did .
Thanks in advance
Pateric
You have a 2008 right? What is the build date for your truck. Wondering, because mine hasn't had any recalls or flashes/TSB's etc.
Old Oct 22, 2008 | 02:06 PM
pateric's Avatar
Build date on my truck was 9/07
I called the dealer this morning and they told me they did the AQ flash, must have forgotten to put the sticker on......
Old Oct 22, 2008 | 09:06 PM
DieselLady's Avatar
So if I went in to get my truck re flashed right now, would they use the same flash as they do on the 08s or do they have a different one still for the 07s. ???
Old Oct 23, 2008 | 04:27 AM
Dodgezilla's Avatar
There are seperate flashes for the 07s and 08s. They may do the same thing but they still have different numbers associated with them...
Old Oct 23, 2008 | 04:33 AM
sabersix's Avatar
Current 07 flash is 'AY' as of Aug 08.
Old Oct 23, 2008 | 07:34 PM
mr. ed's Avatar
Correct! I just had the AY flash performed today at the local dealer. I asked him to install the newer O2 sensors and heat tape, which he did without question. I also asked him to enable high idle, which he did while implementing the new flash. Additionally, he was able to grease the cardan joint, which NO one had been able to locate until today . This dealer is located in Ocala, FL and I must say I'm impressed with their service dep't and the professionalism displayed by their diesel tech.
Back to the AY flash. The tech explained that this flash is intended to help minimize CEL's caused by the O2 sensors by making them less sensitive (or something like that).
Old Oct 23, 2008 | 08:06 PM
mnmlod's Avatar
I have the AX flash, homemade dpf delete and uplugged egr with not a single code thrown. I have and edge juice w/ attitude but forget to let it clear codes half the time. I must be really lucky.
Strong05
May 18, 2009 11:33 PM
Steve V.
Jan 2, 2009 08:53 AM
Flattman
Oct 16, 2007 01:07 PM
CamperAndy
May 18, 2007 12:36 AM
04RAM2500
13
Dec 17, 2004 10:02 PM
